Snapped off front wheel stud
Old Sep 1, 2002 | 08:57 AM
crexer's Avatar
Default Snapped off front wheel stud
I think that one of my lug nuts got crossthreaded and snapped off the stud. What all is involved in replacing it? Do i have to have it machine pressed? 88 crx dx
Old Sep 1, 2002 | 09:13 AM
FastFoot's Avatar
Default Re: Snapped off front wheel stud (crexer)
take off your wheel and then just tap it out with a hammer. then, get a new one, pull it thru. if u have trouble fitting it thru cuz the stud is too long u may have to spin the rotor around and find a gap that will allow the stud to slide thru. once uve done that take a lug nut turn it upside down and tighten it down along with some washers using an air gun. if u dont have access to an air gun i would take a breaker bar and tighten it down. make sure it is pulled all the way thru and seated properly. then ure done!
Old Sep 1, 2002 | 09:29 AM
enabi's Avatar
Ive been driving on a broken wheel stuf for a few weeks now. I bought a replacement one, but it seemed to me that there was no way of removing the old one wihouth pressing out the knuckle. There just wasnt any room for it to go back into. However, I did not spin it to see if there was an opening in the rotor. I dont remember the stock rotors having any openings in them though.
Old Sep 2, 2002 | 12:14 PM
crexer's Avatar
Default Re: Snapped off front wheel stud (enabi)
ttt
Old Sep 2, 2002 | 12:32 PM
primoEF's Avatar
take off wheel, rotor and caliper, pull the hub out with a puller, then you can change all four if you wanted, it is hard to change it without taking the hub out, as well change the bearing if its old
Old Sep 2, 2002 | 12:50 PM
nikitad's Avatar
Default Re: Snapped off front wheel stud (b18k1)
If you really don't wanna pull the hub apart,
you can cut a hole/slot in the tin dustshield and grund some of the stud (both old and beed) off to get them through.
I did it and don't have any throuble since.
Old Sep 2, 2002 | 06:06 PM
crexer's Avatar
Default Re: Snapped off front wheel stud (nikitad)
ok thanks everyone,,,,,,hope it works
Old Sep 2, 2002 | 06:21 PM
FourthGenHatch's Avatar
How much is a Hubpuller and where can I get one?
Also how hard was it to cut the dust shield?
Eclectia
Jun 16, 2013 11:56 AM
thunderlips
Nov 25, 2008 09:34 AM
e jay one
Dec 19, 2006 03:52 PM
drewbie
Welding / Fabrication
Apr 21, 2006 07:28 AM
Cheivic
10
Jul 20, 2003 07:33 AM
