mini me idle issues, can someone help me?
Old Nov 18, 2009 | 04:14 PM
91teg_ls's Avatar
Default mini me idle issues, can someone help me?
i have a d15b7/z6 mini swap in my coupe and i am having some idle issues. the idle bounces from 1000-1500 rpms. i have cleaned the iacv and it is doing the same thing. i took one of my 93 coupe with normal idle and replaced it. but still idles funny and the 93 coupe still has a normal idle. can someone help me? i would like to have this problem fixed before i install the supercharger.
-91teg_ls
Old Nov 18, 2009 | 06:56 PM
Autointeg's Avatar
Default Re: mini me idle issues, can someone help me?
vacuum leak.. re check hoses screws etc.. gadid you get new gaskets? TB gasket? HG etc?
Old Nov 18, 2009 | 06:59 PM
EK2.0's Avatar
Yeah he's right, sounds like you have a vacuum leak at either a gasket or hose!
Old Nov 18, 2009 | 10:02 PM
91teg_ls's Avatar
i think that i have it figured out/ i think that it is my fitv. i will check that tomorrow and replace that.
Old Nov 19, 2009 | 12:25 AM
hard_boiled_EG's Avatar
dam it's been a while but, if i remember, underneath the throttle body, facing the fire wall, there will be a flat plate with 2 fillups screws holding it, take that off and there will be a kinda like spring pushing on a screw, turn that screw clockwise untill it stops don't make a tight, just untill it stops.
that should stop ur ildle problem IF you don't have any vacume leak...
TheOdd001
Jul 7, 2008 07:32 AM
luv2boost
Jun 2, 2008 06:33 PM
95dc2teg
Sep 11, 2007 05:49 PM
Midori Green
Jan 3, 2007 03:13 PM
sik_sol
May 25, 2006 01:56 PM
