Build what I have or buy another motor?
Old Nov 18, 2009 | 12:49 PM
TruespeedEM1's Avatar
Default Build what I have or buy another motor?
I need some opinions. I currently have a 2000 Civic SI and the B16 has about 92k miles. I just got my paint redone and have bought some pretty nice parts for the outside, but the motor is 100% stock. I have a built turbo b16 that I am selling and some audio equipment so that leaves me about 4k to play with. I want to do an allmotor+spray build, but for some reason I really want a Type-R engine, and those run about 4k from hmotorsonline.
Should I buy the TypeR, or build my current b16? Keep in mind emissions and the fact that I dont want a super crazy build.
If I decide to build the B16, I plan on pistons/rods, headwork (cams, valvetrain) a nice intake mani, I/E/H and then spray.
Opinions? Thanks alot.
Old Nov 18, 2009 | 02:48 PM
88Hatchy's Avatar
Default Re: Build what I have or buy another motor?
build a lsvtec for about $1500
Old Nov 19, 2009 | 07:37 AM
Top Ramen's Avatar
Build an LS bottom end and drop it in there.
Old Nov 19, 2009 | 01:03 PM
SergEK's Avatar
If you are gonna build a motor you already have the head (valve job and maybe port work if you can $$$wing it)...all you would need is an ITR block/crank
As far as emmissions go Cali has a ton of rules....dont know where you live...passing the sniffer isnt hard with a good tune but remember the more agressive you go the harder it will be to pass given the NOX content at lower engine speeds.
Most people "have a hookup" to pass the sniffer
Do an F20b on spray - more power everywhere
Old Nov 20, 2009 | 09:46 AM
The only emissions I have to deal with is the OBD2 scan. I live in North Carolina and we dont have the sniffer.
I'm really leaning on just building what I have. Im not sure if I want to spend 4k for a type r swap when I can just basically get everything I'd want to build my current B16 and have money left over.
Old Nov 20, 2009 | 09:54 AM
SIred91's Avatar
Rainman
Get the B18c5 .... that is a drop in 200 hp...it will take ALL your money to get the B16 to that mark and then it will be a peaky no powerband motor.
Old Nov 22, 2009 | 09:55 AM
hmmm different suggestion. Anyone back that up?
Old Nov 22, 2009 | 10:26 AM
SIred91's Avatar
Rainman
If I could go back that is what I would have done for a B series.
Old Nov 22, 2009 | 03:01 PM
SergEK's Avatar
The F20B will make more power than the ITR swap and cost you LESS money.
H2B FTW!
But the OBD2 scan may be an issue because I would run a P28 with eCtune...dont think an OBD 1 ecu is gonna fly
Tough call
Old Nov 22, 2009 | 03:03 PM
it wont, thats my biggest problem.
Ive actually been looking at B20's right now... haha
Old Nov 22, 2009 | 03:10 PM
SergEK's Avatar
F20Bs are already put together with a larger VTEC head, larger bearings, stronger OEM bottom end and Type S cams....all for $1000-1100 ...add the $750 adapter and you have a much better platform to grow on than a Tiny B16 head with a weak "truck" block.
tech23
Sep 21, 2008 08:44 AM
dkboyny11
Apr 25, 2006 02:09 PM
B18Sleeper
Dec 9, 2005 05:02 PM
R1_Owner
12
Dec 5, 2005 10:00 AM
raynaud
Jan 26, 2005 09:27 AM
