Why does jdm b18c have higher comp ratio than b18c1?
Old Nov 16, 2009 | 09:58 AM
twentyhurtz's Avatar
Default Why does jdm b18c have higher comp ratio than b18c1?
ok, BEFORE YOU FLAME, i have searched, several sites, even this one and i ask the same question and get a different answer each time and i really want to true answer, matter of face i have asked this on this site before and couldn't get a straight answer, only post if you really know!
Ok, usdm b18c1 has 10:1 compression ratio
JDM b18c has 10.6:1 compression ratio which equates to the engine having 9 more hp..
Ok, so what is creating this higher compression? I have a jdm b18c in my car, so does my friend, and we have about 4-5 other friends with b18c1, so far, all heads say p72, i'm sure all the rod's, pistons, etc say p72 as well, at one time i "theorized" that maybe the jdm18c had a p73 bottom end since the usdm itr bottom end has 10.6:1 compression.. but when studying the differences in the head i realized that to be wrong..
So what is it causing a compression rise? does the jdm motor have higher compression pistons also stamped p72? in which you couldn't really tell the usdm and jdm apart? One person suggested a thinner head gasket, which i don't believe that because then everyone with c1 motor's would be just swapping head gaskets for 10 more horses..
I just find it awkward how i can't find a straight answer on this question... and besides curiosity, i need to know this in case i have to replace a part, such as head gasket, pistons, etc, so i will know to get the jdm part as opposed to a usdm part which would lower compression..
Old Nov 16, 2009 | 10:55 AM
A L I A S's Avatar
Default Re: Why does jdm b18c have higher comp ratio than b18c1?
pistons hommie lol search??? theres this thing outside of ht i think its called google or something
Old Nov 16, 2009 | 10:59 AM
Takahashi's Avatar
Maybe is for the high octane petrol?? Maybe because if not there is no JDM stuff lol
Old Nov 16, 2009 | 11:01 AM
dpetro1's Avatar
http://www.ff-squad.com/tech/temp/pistons.htm
first result when i typed "jdm b18c piston" into google
Old Nov 16, 2009 | 04:23 PM
ok, well seeing as how i don't know its the piston..... why would i type in jdm b18c piston?...... but thanks anyways.. that link is perfect..
Old Nov 16, 2009 | 10:41 PM
dpetro1's Avatar
well since the piston is the most common way to change compression i thought you might have considered researching piston variances between engines. sorry i if i assumed incorrectly. glad you found your answer.
Old Nov 17, 2009 | 04:58 AM
yes i agree with that, but seeing as how both pistons say p72, that kinda scratched that theory for me, i did not realize there were sub marking on it -00 and -0A, and the fact that i have people saying, thinner head gasket, different head, different valves, different stroke, etc, then it leaves it wide open for me, because obviously all those people don't know either..
88 rex
Nov 2, 2005 01:46 PM
pgpunkguy
Mar 16, 2004 04:04 PM
92 civic VX B18c
Jun 10, 2003 02:43 PM
AEGEAN
Jan 6, 2003 08:58 PM
95hybridcivic
May 21, 2002 06:37 PM
