B16A1 into EG 4 door
Ok, after 3days Iam buying B16A1 not full swap but for great money
in your money it will be ~900$ I will get B16A1 block/head, Y21 hydro gearbox, intake manifold with B18C4 TB, B18C4 exhaust manifold, stock flywheel & clutch, alternator, distributor, starter, shift linkage, and maybe - if Iam lucky some mounts...
So, as I get, I still will need Axels, ECU, and then maybe mounts too.
I got EG8 - 4 door - EDM - it comes with d15b2 engine + I got OBD1 cause i put on d16z6 intake manifold. The guy said that I can run that engine with OBD1, but ofcorse I need obd1 ECU. What mounts do I need to swap it right into my car? What Axels do I need? And what is with POWER STEERING, I got it now, but I will not have it on that b16a1 engine, can I swap it on?
Thanks alot guys
in your money it will be ~900$ I will get B16A1 block/head, Y21 hydro gearbox, intake manifold with B18C4 TB, B18C4 exhaust manifold, stock flywheel & clutch, alternator, distributor, starter, shift linkage, and maybe - if Iam lucky some mounts...So, as I get, I still will need Axels, ECU, and then maybe mounts too.
Thanks alot guys
Iloveyourhonda92
Oct 12, 2014 06:15 PM
datsun510dude
Feb 13, 2003 05:58 PM
