swap from an EG
swap from an EG
ok theres a swap(b18c1) in an eg hatch thats wanting to sell it.
i have a 98 coupe.what would i have to get to make these compatable.i was htinking that the mounts wouldnt work,but what about hte mount brackets and harness jumper.what obd is an eg?
Re: swap from an EG (Capsule Kid)
eg is OBD1, however it may be converted to run the engine. b18c1s were made in 3 different OBD generations as far as I know. I don't know why the mounts wouldn't work, as far as I'm aware egs and eks share identical mounts/engine bays.
Re: swap from an EG (SpydiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpydiR »</TD></TR><TR><TD CLASS="quote">eg is OBD1, however it may be converted to run the engine. b18c1s were made in 3 different OBD generations as far as I know. I don't know why the mounts wouldn't work, as far as I'm aware egs and eks share identical mounts/engine bays.</TD></TR></TABLE>
eg's and ek's have different mounts.......94 & 95 ex/si use the same mounts as the gsr except for the tranny rear bracket and the lower vibration brackets.
https://honda-tech.com/zerothread?id=878010
Imagine that, a helpful link that you would see (if you'd look) right before you posted. I'm sure you could get your questions answered by looking around.
vote: LOCK
vote: LOCK
Re: swap from an EG (TheGeneral)
sorry, ive looked in there plenty of times but i wasnt looking for that info so i overlooked it.and didnt think to look in there since i knew what swaps were available for my civic,but wasnt sure on obds
any part numbers for the brackets?
Civic2Fast
05-23-2008 07:55 AM
HondaFanatic708
04-05-2005 07:36 PM
