HT help?
A couple questions..
I posted this up in hybrid.. but I need to get a solid answer on this soon and they're not coming quick there..
I'm looking at doing a b18b1 (OBD1) swap into my EG.. (no jumper harness required..)
I looked at the gsr writeups (e.g.
http://forums.evans-tuning.com...light)
looks like direct bolt... some writeups had that you need a mount from an integra ..
fact or fiction??
are stock axles are ok for the time being??
Here's what I have compiled as a list of what I need..
Engine
Tranny
ECU
shift linkage
anything more that I'll need??
I'm probably going to replace my mounts if I do the swap... should I get mounts for a teg, or will the EG mounts suffice?? I'm just goin the OEM route with the mounts..
I know a lot of questions.. all help is appreciated!
Modified by 95civhb at 5:30 PM 12/21/2006
Modified by 95civhb at 5:31 PM 12/21/2006
fact or fiction??
Engine
Tranny
ECU
shift linkage
Re: A couple questions.. (95civhb)
Stock Integra axles will work, yes.
Search is working real slow for me, otherwise I'd post a pic of the mounts you need. You can use stock upper tranny mount, two front torque mounts, and the crossmember mount. From the Integra, you need the lower front tranny bracket, rear tranny bracket, AC bracket, and driver side mount.
Are you using the B1 harness?
