hesitation problem
Hey guys, so the ol d15b2 gave up in my 91 hatch
a friend gave me a d15b7 he had sitting around so i threw that in
i changed over the intake, driver eng mount etc etc
so it runs good but it has a hesitation at lower rpms
if you snap the throttle wide open from a idle it will bog slightly then take off
if your driving the car its a little underpowered at lower rpms, but once you get going its fine
Any suggestions?... the sparks plugs are a little worn out and the cap and rotor might be a little dirty but i wouldent think this would make it run like this
ive checked vaccum lines and nothing seems out of place
any help would be awesome, thanks.
sounds just like what my car did, My tps wasnt calibrated properly. The same time we did that we got my check engine light to go away by fixing my intake air temperature sensor. But i dont think the sensor affected it. Im pretty sure it was the tps.
mrmoomoox
May 10, 2010 07:42 AM
soLaLive
Feb 15, 2010 04:35 PM
