91 Integra problem with sputtering/bogging.
Old Feb 5, 2013 | 12:50 PM
DA_bbobert's Avatar
Default 91 Integra problem with sputtering/bogging.
When my car starts up it runs normally until it warms up, when it warms up it bogs when i hit the throttle. I feel like there is a loss of power.
It also takes an abnormal amount of time to warm up, like 5 minutes.
I have not done anything yet, just curious if someone else had a problem like this, and how they fixed it.
From 500-2500 rpm car sputters, at 2500 rpm+ it is fine if that helps at all.
** Replaced Fuel Filter and Spark Plugs. Sort of helped, but still bogs a lilttle at low rpms.**
Old Feb 5, 2013 | 03:40 PM
fcm's Avatar
fcm
Old Fart
Default Re: 91 Integra problem with sputtering/bogging.
Need a lot more info, besides MM&Y, trim level will also help, any mods?
Have you checked/tried anything?
Basic stuff first, spark, [is it a good spark] fuel pressure, [what is it] and timing both valve and ign. timing, [confirm both are correct]
Fuel filter, when was it last replaced/
Long warm up, almost always a thermostat stuck open.
Easy start/runs "normal" untill warm. may be a bad ECT sensor, you may be running rich, the Engine Coolant Temperature sensor supplies the ECU/ECM with engine temp., as the engine warms up the ECU/ECM will adjust A/F ratio, rich at start up of cold engine, leaning it out as engine temp. goes up.
Hard starting of an already warm engine is also a symptom of a bad ECT sensor, so is **** poor gas milage. 94
Old Feb 5, 2013 | 05:04 PM
ProjectEvilEj2's Avatar
new spark plugs and wires! trust me! change it and let me know wwasuppp
Old Feb 6, 2013 | 07:13 AM
acura_madness's Avatar
true might need a tune up on it also like FCM said thermostat stuck open too.
Old Feb 6, 2013 | 08:25 AM
stocker2shocker91's Avatar
I requested a short story for a title.
is this an intermitten problem or is it everytime you go for a drive?
also is the check engine light on?
sounds for sure like its running rich.
Old Feb 11, 2013 | 09:45 PM
ek4ther's Avatar
I had the same problem with my db1. I just set my distributor in advance. The blogging disappear. Before I set my distributor to advance I put new spark plug and wires blogs less but didn't fix the problem.
Old Feb 11, 2013 | 09:56 PM
Connected sedan's Avatar
I am having the same problem I turn it on its stuck on cold when I shift Into second it Boggs down leading to the car shutting off I cleaned the plugs they didn't seem to damaged it ran for thirty mins than wouldn't start , should I do new wires and plugs or could it be a MAP sensor or fuel filter ? Thanks it's my only car and first civic just stock
Old Feb 12, 2013 | 05:39 PM
DA_bbobert's Avatar
Do you know hot to fix ECT sensor?? Or Thermostat stuck open?
edulerp39
Dec 1, 2014 01:26 PM
GT500FTW
Oct 5, 2012 02:26 PM
DX_Accord_22L
Jun 28, 2009 01:14 PM
Montx
Apr 28, 2009 05:47 PM
Charlescox
Dec 8, 2004 05:26 AM
