another vaccum routing problem. HELP :P
Old Nov 12, 2009 | 11:14 PM
omiehomie's Avatar
Default another vaccum routing problem. HELP :P
so im almost ready to take my car for a tune. the only thing that i need to do is the vac line routing. i have searched on HT and i have the diagrams that tail put out on their website and still no dice. i went ahead and made a picture and i was wondering if i maybe could get some help
i was wondering if people that have similar setups could chime in and let me know how they are routing thier lines for the best responses? i have a vac block and i think i have most of the lines done but im totally clueless about the WG and the lines because it has two ports?
any help is appreciated. thanks again
here is the diagram
here is the real think so you dont think im losing my marbles
Old Nov 13, 2009 | 01:39 AM
Hoe Hopper's Avatar
Default Re: another vaccum routing problem. HELP :P
I think your suppose to route the lines from your wastegate to you boost controller.
Old Nov 13, 2009 | 06:40 AM
NonovUrbizniz's Avatar
Loved
The compressor outlet V1 goes to V2 the side port on the WG.
Then a Line from your vacuum manifold goes into the Boost Controller and out of the boost controller to the top port on the WG.
P.S. You should cut off abt 1-2 inches of that top radiator hose (on the radiator side) so it doesn't bind like that... that will not bee good for flowing coolant into the head.
**EDIT**
Let some people reconfirm this I'm not 100pct on the side/top ports for the WG and I'm not 100pct on which ports on the MAC selonoid is in and out.
Old Nov 13, 2009 | 02:47 PM
jdm95's Avatar
Thanks for the diagram but it was a little confusing. Heres how it should be. Line off the v mani to the boost controller out the other side to the top port on your w/g. Another line of the v mani straight to the bottom port on the w/g. Then another one off the v mani to the blow off vavle. Then run any other lines your needing to the boost gauge or whatever. Correct me anyone if im a little screwed up but thats the way ive always known it . What map are you running?? I just hooked up a omni plug and play. Just wondering.
Old Nov 13, 2009 | 04:57 PM
omiehomie's Avatar
hey bro thanks for the response im running an AEM 4.5 bar map sensor. it wires into the stock wiring and i just need a vacuum source from what i have been told.
thanks again everybody for the help, any more input would be appreciated.
CleanLikeJdm
Jul 3, 2006 07:32 PM
CivicVX94
Feb 21, 2006 04:57 PM
RACEPAK
Oct 1, 2005 10:10 AM
crxdonwon
Feb 25, 2005 03:19 PM
shivic
Aug 22, 2003 10:15 AM
