What gauge wire to use for battery relocation to the trunk?
Old Nov 12, 2009 | 07:50 PM
92integraVTECgsr's Avatar
Default What gauge wire to use for battery relocation to the trunk?
I have to relocate my battery to the trunk in my 00 Integra GSR. What gauge wire would be the best? I bought a Rockford Fosgate 4ga power wire kit today. I think that should do the job, but I just wanted to make sure.
Old Nov 12, 2009 | 07:53 PM
TypeRfit's Avatar
RESIDENT
Default Re: What gauge wire to use for battery relocation to the trunk?
You are correct sir, at minimum do 4 gauge, i personally ran 2 gauge in mine, but 4 gauge will do the job.
Old Nov 12, 2009 | 08:19 PM
thanks, it was all they had in stock @ work and i needed it today
Old Nov 12, 2009 | 08:56 PM
TypeRfit's Avatar
RESIDENT
Anytime, Did you get good terminals for the kit?
Old Nov 12, 2009 | 09:15 PM
I just got the RF distribution kit so I can connect all my wires under the hood to the power wire and run it to the back.
Old Nov 12, 2009 | 09:17 PM
B16Drag's Avatar
At least a 4 gauge but the smaller the gauge the better.
Old Nov 13, 2009 | 01:06 AM
chaz_w16's Avatar
i put the starter wire and the fuse box wire at 4 gauge and ran them into a big fuse then went 0 gauge back to the battery
Old Nov 13, 2009 | 06:44 AM
TypeRfit's Avatar
RESIDENT
Sweet, You shouldn't have one issue then. Have fun doing it and post up some pics when your done
Old Nov 13, 2009 | 07:50 AM
Bond's Avatar
I used 0. I would suggest to go min4 but 2 or 0 is great. Install a circuit breaker aswell!
Old Nov 14, 2009 | 07:46 AM
Well I ran the 4 gauge and everything is working great so far.
Old Nov 14, 2009 | 08:42 AM
Rediness_code's Avatar
I gotta do this to my car also, how long did you get the wire? how much u pay?
What are you using to hold down the battery in the trunk?
Old Nov 14, 2009 | 10:54 AM
twentyhurtz's Avatar
you mean the lower the gauge # the better.. cause too small of a gauge <4 would be bad... voltage drop, ie.
Old Nov 15, 2009 | 04:47 PM
Bond's Avatar
Do not overlook running a circuit breaker guys. The added length will cuase a higher current draw so put one in to be safe
Also just spend a little extra and get a battery box. One of the best things I bought when doing my relocate.
Old Feb 22, 2018 | 08:33 AM
cubnsensation's Avatar
hey bud, i know i am late to this but i was wondering what size cable did you use to run the power from your fuse box to the battery? assuming you didnt move the battery to the trunk as well.
alex14
14
Nov 11, 2010 12:56 AM
91(si)hatchey
Jul 29, 2009 08:16 AM
essex
Jun 7, 2008 11:11 AM
G2ILS
Jan 17, 2005 12:14 PM
speedemon
Jan 13, 2005 09:43 PM
