Some motor questions. Help
Old Nov 12, 2009 | 04:32 AM
drummerboyjames's Avatar
Default Some motor questions. Help
Hello i been a member here for awhile just never posted, but i been gathering parts for a build.
I have a B18B block and a B16 head.
im trying to build the motor to a 13:1 compression.
i have a shop decking and sleveing my block, and my head im gettin p&p, plained, and a 7 angle vavle job.
here is what i need some help with.
Should I get oversized vavles?
What type of cams are best?(performance wise)(when the build is done it will be driven a good bit. not daily but no just sitting)
Are skunk2 cams overrated?
What are opions of dual rate springs?
I have a ls crank that was balanced and micro polished. Is getting another crank overkill?
i just need some opions on what would make this a killer build, i no basics, not much more. lol
anything eles im forgeting let me no.
help is greatly appreciated thanks james,
Old Nov 12, 2009 | 08:10 AM
all-mtr-teg's Avatar
Default Re: Some motor questions. Help
Why 13:1 CR? Pic your cams first, then build the motor with a suitable C.R.
I'd say skip the 7 angle valve job. Most of the time a 3 angle valve job is good enough.
Who is sleeving and porting the head? Why aren't they giving you any build/parts advice?
No S2 cams are not overrated. They put in a lot of time and money into developing cam profiles that make power.
Springs should match the cams to avoid warranty issues.
OEM crank is fine.
Old Nov 12, 2009 | 06:09 PM
thanks for the reply, ucf in carlisle pa is doing my work. They mainly do Flat heads and older motors. just trying to get on advice from the street.
MillanoEKhatch
17
Nov 26, 2008 11:10 AM
one bad dx
56
May 26, 2007 09:00 AM
jdmkid8383
May 20, 2007 07:31 PM
joshyeame
Feb 9, 2006 08:43 PM
Freakin-Rican
Dec 22, 2004 06:19 AM
