Need some Help On Building My Motor
Old Dec 21, 2004 | 05:35 AM
Freakin-Rican's Avatar
Default Need some Help On Building My Motor
Im tryin to build a motor for my 99' Honda Civic Si, ive got around $4,200.00 dollars to play with and i want to build a motor capible of about 220 to 230 WHP. Does any one have any suggestions on were to get a good B16 block thats alreayd done up or any web sites i can check out?
Also these are the parts ive found so far: Golden Eagle B16 Block, Bored & Honed 85mm, Line Bored with Godzilla Sleeves. The Head is a Bull Frog complet package that is bored out with a bored throtle body and intake man. the head is capible of producing 50-60Hp. Does anyone think this will do the trick?
Old Dec 21, 2004 | 02:59 PM
ELAMINT5's Avatar
Default Re: Need some Help On Building My Motor (Freakin-Rican)
OK, have you blown your current motor? If no, the Si comes with a B16A2, so why do you need another one? If it is blown get a B18B block and B16 head and 9.1 CP pistons, GSR cams, Ferrea Valve Train, and Drag Turbo! That will get you there and should be close to 4200! Welcome to H-T! And good luck!
Old Dec 22, 2004 | 02:17 AM
Default Re: Need some Help On Building My Motor (ELAMINT5)
Hey thanks for all the info, its hard to find good help these days. I Looked up all the parts that u said and it will run me about $4,300 thats not bad at all. I got one other question if i was to buy a B16B Type R motor would all my after market products from the B16a fit on the B16b?
Old Dec 22, 2004 | 06:19 AM
CompressionFed's Avatar
Most of the stuff will fit, it may be close on the header though. We have used a b16 DC 4-1 on an LS and it was close. If I remember correctly, the b16b has a taller deck height that the b16a.
But let me ask you this...why spend all that money on a b16b? You could build a bigger, badder motor with the same money.
drummerboyjames
Nov 12, 2009 06:09 PM
eg6-trans
Dec 27, 2007 05:25 PM
B_series_
Aug 6, 2005 11:03 PM
B16Civic93
Oct 22, 2004 01:50 AM
