1991 Honda civic vibration problems
Old Nov 10, 2009 | 09:05 PM
Kwiz5's Avatar
New User
Default 1991 Honda civic vibration problems
yes I have a 1991 Honda civic with a b16a in it with hasport motor mounts. and skunk2 shocks in it with coil overs. and 15 inch drag rims. I can not find out what the problem is. And it has new axles and wheel bearings and rack and pinon in it. And all new lower control arms in the back and upper on the front. And would the coil overs make it vibrate if the where put them on wrong. And it vibrates at 10 to about 65.
Old Nov 10, 2009 | 09:15 PM
DVS_SI's Avatar
Default Re: 1991 Honda civic vibration problems
Check you tire pressure and balance your wheels.
Old Nov 10, 2009 | 09:22 PM
Kwiz5's Avatar
New User
I check the tire pressure and balance the wheels all ready. I no i need a aliment. But before i go do that. Would you thank I should redo u the coil over. Because I had some put the coil overs on and the put them on wrong. They put the adjuster on top of the coil and stead the bottom of it.
Old Nov 10, 2009 | 10:16 PM
Rob.'s Avatar
- aligenment
- tire balancing
- check front end suspension
If your axles are shot, this can cause it too.
Old Nov 11, 2009 | 12:41 AM
Eks_86's Avatar
check your axles u might still have the cover its a circle black plastic ....
Old Nov 11, 2009 | 01:23 AM
jose0490's Avatar
yup, check your front end suspension..
Old Nov 11, 2009 | 03:24 AM
~sp33~'s Avatar
EFB055
What the hell? lol.
That wont cause the issue you're having, but seriously, how do you manage to stuff that up haha.
Old Nov 11, 2009 | 10:23 AM
Kwiz5's Avatar
New User
OK I will check the front suspension first before I go get an alignment.
Old Nov 11, 2009 | 12:19 PM
EJ1_Sleeper's Avatar
step one fix your coilovers....
where is the vibration coming from? front or rear? did you replace your Rear trailing arm bushings? make sure everythings tight. make sure the racks adjusted properly, and make sure your removed that rubber dust ring around the axle where it slides into the hub.
Old Nov 11, 2009 | 02:47 PM
Kwiz5's Avatar
New User
The vibration is coming from the front passenger side of the car. And I replace the bushings in the rear trailing arm bushings with skunk2. I thank when I got my wheel bearings done at pep boys the for got to give my the dust cover back after they put the new wheel bearings in.
Old Nov 11, 2009 | 02:53 PM
Kwiz5's Avatar
New User
No I did not replace the trailing arm bushings. And it might becoming from the back to.
jimjanc
Honda CR-V & Element
Oct 12, 2019 06:57 AM
EeF
13
May 31, 2010 12:36 PM
Golferdude1977
Aug 5, 2006 05:30 PM
rice a roni
13
Jan 19, 2005 09:42 AM
JDM_CD7
Apr 22, 2003 11:42 AM
