f22b2 no compression... need help
i just bought a 94 accord with the f22b2 for $250 body in good condidtion. the people i bought it from said the pistons where bad then they said the head gasket was bad thin they said there was a bent valve.. i redid the timing and did a compression test.. i had no reading for each cylinder. my question is do i have a cracked head or are the piston rings fried. it had a overheating problem an was smokein bad.. anything??????
