B16A2 Swap Into 92 Eg Hatch, Need Expert Help
Old Nov 7, 2009 | 10:10 PM
cancel's Avatar
Icon3 B16A2 Swap Into 92 Eg Hatch, Need Expert Help
Alright so I have a 92 CX hatchback that im rebuilding a B16A2 back to oem specs. I currently have the 96-97 OBD2 P28 Ecu from a del sol, a 97 GSR Engine harness, B16 Axles, pretty much complete change over.
Now my question is,
How do I convert my OBD1 Ecu harness to OBD2 WITHOUT using a jumper harness?
The reason why I need this is because I'm trying to bar legal the motor. I've looked on like 10+ pages and all I found was distributor conversions and a bunch of conversion harness. Can I just find a OBD2 Ecu harness from a integra/si/del sol and pull it and plug it into my eg or do I have to splice cut etc wires?
I'm trying to find a guide so that would be great help!
Old Nov 8, 2009 | 12:12 AM
freshvibes's Avatar
Default Re: B16A2 Swap Into 92 Eg Hatch, Need Expert Help
You'll have to get all 3 obd2 ecu plugs and re-pin all of your wires and if the pins differ between them than I'm assuming you must cut and solder.
As you can see by the diagrams you're dealing with quite a few wires, I would go with a jumper harness if if I were you but if you have the patience it is doable.
OBD2a Pinouts
OBD1 Pinouts
Old Nov 8, 2009 | 12:17 AM
ekb16a's Avatar
jump harness unless u know what ur doing and sence ur asking i bet u dont have idea wth u wanna do
play it safe n smart jump it !!!
amd honesly this doesnt make sence to me
Old Nov 8, 2009 | 01:05 AM
es01civy's Avatar
First go to the state ref and ask if you are allowed to use a jumper harness. I am sure you are because your upgrading in OBD not vise versa
Old Nov 8, 2009 | 01:27 AM
angel_i's Avatar
use the ecu from a 93-95 Del Sol Dohc Vtec(b16a3)
Old Nov 8, 2009 | 02:22 AM
es01civy's Avatar
he cant a2 is a obd2 ecu and a p30 aka a3 is a obd1 needs to be matching ecu with motor
Old Nov 8, 2009 | 07:38 AM
angel_i's Avatar
Oh yeah, Cali.
Old Nov 8, 2009 | 09:42 AM
cancel's Avatar
i know exactly what im doing if it doesnt make sense to you then you dont need to be telling me what i dont know how to do, kinda like how you say my stuff is over priced in my for sale thread
yeah i've already asked the state ref, they don't want people using jumper harnesses
and thanks vibe ill look into that
the reason why i need this to be done legit because im gonna bar legal the car and register it as a custom car so the smog laws are a lot more lenient on me rather than a normal California regulated car
Old Nov 8, 2009 | 07:05 PM
ryanhauk's Avatar
im glad indiana doesnt have to worry about that stuff.....man that would suck
Old Nov 8, 2009 | 08:40 PM
Lord Yod's Avatar
The only way you'll be able to do this is to repin the ECU harness connectors. It'll take some time and effort but if you do it correctly it'll be worth it.
You won't be able to register the car as a 'custom car' since it was manufactured, but you'll be able to get a BAR label on it. That won't relax the emission inspection limitations on it, it'll just allow you to pass at all, since you'll be testing the car as either a 96-97 del sol or a 99-00 si.
killaberna
27
Aug 26, 2014 06:44 PM
mikeycivics
Apr 22, 2014 01:23 AM
JDCB16Cx
Feb 26, 2007 12:15 PM
balleur
Aug 9, 2005 08:10 PM
