THROWIN CEL 43
Old Nov 5, 2009 | 10:04 AM
blkcivic310's Avatar
Icon2 THROWIN CEL 43
so i have a 97 gsr in my 95 civic coupe it ran fine for about the first week then started throwing code 43 it came on once befor work then at lunch it didnt come on agian till 2 days later and now it come on just about everyday i let the car run for 5 min warm up and i leave and it runs fine then it will pop on i was told to just change the feul filter but i was trying to get your guys opinion it also baugs sometimes not all the time but if im cruzin and try to exellerate it will baug and i let off the gas and get on it and it runs perfect im stuck
Old Nov 5, 2009 | 10:12 AM
shoklid's Avatar
Default Re: THROWIN CEL 43
well car will run like poop if its not getting fuel.
Old Nov 5, 2009 | 10:13 AM
thats what i was thinkin two and the car run just fine
Old Nov 5, 2009 | 11:42 AM
Former User's Avatar
Could be a bad O2 sensor if the car runs fine.
Old Nov 5, 2009 | 12:44 PM
shogee's Avatar
sounds like a plugged fuel filter, it only boggs when you wot?
Old Nov 5, 2009 | 12:49 PM
not WOT but prolly close to it but it doesnt do it all the time
Old Nov 5, 2009 | 01:07 PM
Originally Posted by blkcivic310
...it also baugs sometimes not all the time but if im cruzin and try to exellerate it will baug
...the car run just fine
There's a disconnect here.
If code 43 is accompanied by poor engine performance, then concentrate on the fuel system. Start by measuring the fuel pressure.
Old Nov 5, 2009 | 02:15 PM
yea i said sometimes it runs fine 95%percent of the time it doesnt baug enought to say its runnin bad but thanks for all the ideas cummin in its givven me a good starting point
shogee's Avatar
sounds like plugged filter if you havent replaced it yet, plugged filters show up during accel not in idle
Old Nov 5, 2009 | 02:31 PM
so i should try to change what the feul filter are their other filters i should check two
Old Nov 5, 2009 | 06:49 PM
shogee's Avatar
just the fuel filter its by the firewall youll see a line going from the fuel rail to the filter
Old Apr 8, 2010 | 07:59 AM
changed the fuel filter FINALY and fixed the problem
DumaDA
Feb 13, 2017 08:48 AM
roc0487
Dec 26, 2008 05:29 PM
90_Si
Aug 23, 2007 06:46 AM
93CharcoalHatch
Oct 20, 2005 03:15 AM
EFb18b
Sep 11, 2005 03:41 PM
