choice of Wideband
I switched to the Innovate LM2 recently. Bought it through C.H./Xenocron (who hooked me up with a pricematch to his competitor). Only issue I had with it, is once again, cig light plugs generally don't have enough voltage to make the heater circuit work. I chopped the cig plug and added some clips to attach direct to the battery...no problems whatsoever.
I also like having the readout (which is backlit...nice) so that you can compare to what your seeing in the management to be sure your dead on or if you need to add offset.
