cold start...........idles up and down
Hey i got a 93 civic coup ex with 190k miles. Its all stock and runs good. Only when I start it the rpm's jump from like .8k to like 2.5k untill it warms up. I cleaned this one thing in the back of the intake manifold and it helped but still does it now. When the car stands over a cold night, it is worse.
THANX
Anything helps
THANX
Anything helps
man it could be any sensor tps, map,but its soundin like the iacv try replacin the idle air control valve....... they are by no means cheap but try it..... go to a junk yard and try to find one.....
check this link it will tell you a lil why a car has all these sensors....
http://en.wikipedia.org/wiki/Digifan...agement_system
JDMpride
Oct 5, 2010 03:32 PM
