OBD2 B18c1 in a 93 EG Hatch, question
Old Nov 2, 2009 | 08:23 PM
92integraVTECgsr's Avatar
Default OBD2 B18c1 in a 93 EG Hatch, question
quick question,
Is there an OBD1 to OBD2a Jumper harness so I can use a OBD2a GSR ECU in the civic? Or do I need to get an OBD1 GSR ECU?
Old Nov 2, 2009 | 09:22 PM
midnitesol's Avatar
Default Re: OBD2 B18c1 in a 93 EG Hatch, question
you'll wanna get an obd1 ecu its easier than wiring up other sensors to get it to run right and its better for tuning in the future.
Old Nov 4, 2009 | 03:18 PM
duh, forgot about the rear O2 sensor. Ok scratch that idea.
Anyone have a link that shows me which wires need to be pinned on the ecu plugs and shock tower plugs? (VTEC oil pressue, VTEC Solenoid, Knock Sensor, IAB)
Old Nov 4, 2009 | 03:46 PM
portenio78's Avatar
I have done this swap. It all plug n play. Use the obd2 engine harness, which plugs up to the stock eg harness, and just run a chipped p28 that will let you disable knock and o2. Easy as pie!
Old Nov 5, 2009 | 10:12 AM
B18CivicEJ8's Avatar
x2 True story.
https://honda-tech.com/forums/showth...highlight=swap
Old Nov 26, 2009 | 01:30 PM
accord2civic2prelude's Avatar
or go to locash racing and get a obd1-obd2a jumper. i used it on my gsr and it worked great to me.
f22a
Jan 4, 2010 04:09 PM
jamelin
Oct 10, 2009 04:53 PM
EG8GSR
Oct 25, 2007 10:50 AM
OTI-
Dec 20, 2006 04:30 PM
