Honda Check Codes. So Many
Old Nov 2, 2009 | 06:52 PM
CivicSI87's Avatar
Default Honda Check Codes. So Many
I have 97 civic ex, made si. I've posted on here about problems before. It has a p72 computer from a gsr. It still doesnt cross vtec after replacing the vtec solenoid as well as the vtec switch. It was originally throwing 6 codes, then threw 3 codes, and is now throwing 9 codes. Im quite confused and need some serious help. someone please help. here are the current codes its throwing. Someone give me suggestions please of what to do
codes:
22 - --( just replaced)
23
41
54
65
Old Nov 2, 2009 | 07:04 PM
acake em1's Avatar
Colonel Cake Mix
Default Re: Honda Check Codes. So Many
they are all sensor codes man... i would start with the primary o2 sensor code 41
Old Nov 2, 2009 | 07:19 PM
Vindicator9000's Avatar
318 Curves, 11 miles
Yep. That one will cause a bunch of other stuff.
What engine are you running? Is your P72 chipped/tuned? A P72 will throw at least IAB codes on anything but a B18C1 even if everything's working right.
Old Nov 2, 2009 | 08:17 PM
CivicSI87's Avatar
Im running a jdm b16 motor. I honestly dont know if the computer was tuned or not. I've replaced the plugs,wires, redid the timing, changed bad fuses, oil change, whole proper tune up and tried to fix some of the check codes. But everytime i fix one either all go away for a little then come back twice as many. Its crazy.
Old Nov 2, 2009 | 09:26 PM
phazedd's Avatar
speed sensor hooked up?
Old Nov 2, 2009 | 11:04 PM
MHDesigns's Avatar
Get it tuned.
Old Nov 3, 2009 | 01:47 AM
ekb16a's Avatar
u should use p2p see if u get same codes
Unphzd
75
Dec 16, 2010 08:27 AM
esca
Oct 13, 2004 07:50 PM
SearchBeforeUPost!
Mar 31, 2004 06:54 PM
fsck3r
Aug 17, 2003 11:46 PM
cyvic
Jun 5, 2003 02:45 PM
