how to remove valve cover?
Old Aug 30, 2002 | 03:58 PM
rasta420's Avatar
Default how to remove valve cover?
hey guys,
how do i remove the valve cover? what do i need to remove (bolts, distributor, timing belt???) exactly?
thanksssssss
p.s. - also, when i paint my valve cover, am i supposed to clean the other side of the valve cover (the inside of the cover) ? is it ok to get the paint stripper inside of it? safe to clean out with water?
Old Aug 30, 2002 | 04:02 PM
ThatRicerDaniel's Avatar
Default Re: how to remove valve cover? (rasta420)
just the spark plug wires and the bolts holding it on ~ member to make sure you know where the spark plugs wires go otherwise car wont run if there not right . clean the inside with brake cleaner. and dont paint it unless your using high temp paint of it will just burn off and look terrible.
Old Aug 30, 2002 | 05:20 PM
KEVlN's Avatar
New User
Default Re: how to remove valve cover? (NitrousDreamz)
Also, make sure valve cover is cool, and then apply jet stripper to it. Remove paint. It will basically peel off(don't use your hands when peeling paint), then clean again, lightly sand, and paint. Put back on, drive your car hard, heat will help paint stick. later.
Old Aug 30, 2002 | 06:17 PM
wronghand's Avatar
You have to take the plugs out as well.
rasta420's Avatar
Default Re: how to remove valve cover? (Civic95)
how did you guys cover up the lettering (if you did) ? what did you use?
Old Aug 30, 2002 | 06:26 PM
USDM 4G VTEC's Avatar
we dont
just use a nice , new, SHARP, razor and take the paint off of it after its dry!
works fine and perfect for me....
Old Aug 30, 2002 | 06:36 PM
MilanoRex's Avatar
Default Re: how to remove valve cover? (JDM EF9)
seriously take the time to strip it right the first time... i learned that the hard way
Old Aug 30, 2002 | 07:46 PM
rasta420's Avatar
Default Re: how to remove valve cover? (MilanoRex)
thanks for all the help guys.
the valve cover is out, and stripped and sanded. just thinking of a way to make the lettering a different color.
by the way: didnt have to take the spark plugs out~
Old Aug 31, 2002 | 02:54 PM
KEVlN's Avatar
New User
just spray some of the paint into a cup and paint it on the letters ver carefully, otherwise just sand it down when it is dry. Either way.
Old Aug 31, 2002 | 05:24 PM
rasta420's Avatar
oh man, messed up the paint...should i strip it and start over? or add a coat on top??
Old Aug 31, 2002 | 05:40 PM
hybridhatch90's Avatar
strip and start over. trust me.
Old Aug 31, 2002 | 05:58 PM
FBPninetynineEM1's Avatar
Default Re: how to remove valve cover? (hybridhatch90)
ohhhhh **** hahhahahaah
Old Aug 31, 2002 | 07:32 PM
Denny317's Avatar
you should try using a paint marker to do the letterings...
Old Sep 1, 2002 | 02:48 AM
NikoZai's Avatar
i'm not reading everything so i may be reposting but
go to the link on mah sig. All ya need to know about your b16CRX! Its verynice to have!
Old Sep 1, 2002 | 01:57 PM
photonjedi808's Avatar
strip all the paint and just polish it. painted valve covers look ugly if not professionally done with paint that matches your car. I hope you didn't paint it red for that "type R" look
Old Sep 1, 2002 | 07:42 PM
Stupid Ass's Avatar
Default Re: how to remove valve cover? (photonjedi808)
Whats wrong with red? Some people want the valve cover to match the color of their car... so if its red, why not paint it red... that doesn't mean they want "the TYPE R look YO!"
Old Sep 1, 2002 | 08:19 PM
slowman's Avatar
I took way too long
Default Re: how to remove valve cover? (SOHC NoTEC)
this is mine. my car is red and this looks pretty damn good IMO.
Old Sep 1, 2002 | 11:15 PM
brad.'s Avatar
EF9_TryMe
Apr 24, 2010 04:21 AM
HIM1989
Dec 8, 2008 06:56 PM
BEYAAAH
Jun 4, 2007 11:17 AM
ih8danoles
Oct 27, 2002 01:22 PM
civicsport
Jul 17, 2002 07:04 AM
