H2B alternator bracket (Ef chassis)
I have a really quick question for all my fellow H2b'ers Well I plan on buying a alternator kit since I have a h2b in my 1991 honda crx my question is can you please give me your personal opinon or advice on wich one will work better (I am not useing Balance shafts removed Kaizenspeed kit) on EF chassis
Your going to want to run our ESP Upper D or H 1/2" over alternator kit. Removing the balance shafts/pulley is a must, this will move the crank pulley 1/2" over towards passenger side. Run the KS spacer on the outside of pulley or a modified OEM pulley as the spacer.
You will then need to not run the timing belt plastic or notch in route of alternator belt.
2 things to consider purchasing:
ESP EF H22/F Traction Bar System
I have a quick question so if I buy the kaizen speed balance shaft eliminator kit& (Ecplicit speed performance) h22 alternator tensioner kit I should be good with the clearance right ???
Jet Black
Aug 21, 2005 05:55 PM
EKCivicR
Mar 28, 2004 05:58 PM
