Snapped valve cover stud
I went to pick up a d16y7 today, seller said it's great condition etc. Turns out it has 2 snapped valve cover bolts. There's no space at all to grip it, it snapped .1cm from the surface. Any way I can get it out?
What Ron said is the best way to remove the valve cover bolts. If the threads are in good shape, it should be easy to remove once you used a dremel tool to make a groove similiar to a flat head screw. The easy out tool requires you to drill a hole perfectly centered on the bolt without disturbing the threads on the head. I had a 93 Civic with a busted valve cover bolt and it only took a few minutes to remove it with a dremel tool.
00ekcoupe
37
Sep 5, 2005 06:15 PM
