Snapped a valve cover bolt
Old Jan 7, 2003 | 02:43 PM
Biggspeed's Avatar
Default Snapped a valve cover bolt
Yup... it sucks!! I already did a search on this topic but it really didn't help me due to the place where my bolt snapped. Most people suggested to use a vice grip or etc. to unscrew the bolt. That's not my case, the stuck part of the stud is now sitting flush with the head. I'm pretty sure that I have to drill it out. So my question is.... Has any1 ever drilled a valve cover bolt out? Any tips on how to do it? Has any1 ever used EZ outs and r they worth purchasing?
Thanks in advance!!
Old Jan 7, 2003 | 03:18 PM
RaceTilIDie's Avatar
Default Re: Snapped a valve cover bolt (Biggspeed)
Have you tried just pushing down on it with your finger and turning it? If the flange is broken off, that is what torques it, I have been able to do this on occasion, just not on the head bolts.
Old Jan 7, 2003 | 03:19 PM
Tetsuwan Atomu's Avatar
Thanks in advance!!
good question...I have the same problem...after polishing my valve cover....I just left it there..since its fine...but I know it's dangerous and should get it fixed soon
Old Jan 7, 2003 | 04:14 PM
Biggspeed's Avatar
Default Re: Snapped a valve cover bolt (RaceTilIDie)
Hmmm... I'm pretty sure it is too tight to just turn it by pressing down on it but it's worth a try. I have been driving around with this problem for awhile and just maybe... just maybe... the vibrations from the motor could have loosened it a lil' bit. Thanks! Any other suggestions out there?
Old Jan 7, 2003 | 05:02 PM
BluntMan's Avatar
definitly get the ez outs! ive used them dozens of times in your situation. just drill a small shallow hole in the back of the snapped bolt. give the ez out a few taps into the hole you drilled, and crank it out. i can almost garuntee you it will work if you do it right. im gonna go ez out a snapped bolt out of my friends cam in his b18a tonight. good luck! late...............
Old Jan 7, 2003 | 05:37 PM
Kataku2K3's Avatar
Default Re: Snapped a valve cover bolt (BluntMan)
I am not familiar with these "EZ outs" that you speak of, hehe... What i've had to do on occasion is just use a screw extractor... All you have to do is drill a tiny tiny hold in the screw that is snapped off, and tap the little extractor in a bit... It's basically like a reverse threaded drill bit... once you've got in on you can back it out (just about 100% of the time)... Maybe this is what an EZ out is huh??? Oh well good luck!
Old Jan 7, 2003 | 05:57 PM
Biggspeed's Avatar
Default Re: Snapped a valve cover bolt (Kataku2K3)
Yup, the screw extractor that u r talking about is the EZ outs I believe. They work just the way u explained it. I think I will go with the Ez outs. Thanks guys for all your help.
Old Jan 7, 2003 | 06:18 PM
tominos's Avatar
yep, snapped my valve cover bolt too a while ago. bought a new bolt and washer from the dealer and replaced it. if you don't have access to ezouts, you can just drill a hole in the stud, and use a screwdriver to turn it. those bolts break so easily. i used the ezout and it didn't even drill in, cuz it was so easy to turn. try the screwdriver method. good luck
Old Jan 7, 2003 | 06:29 PM
BolognaBlake's Avatar
Default Re: Snapped a valve cover bolt (tominos)
well my problem is slightly diffrent. I have snapped they head off of a shock tower bolt when putting on my bar. Ive been driving it around for a while with no ill effectsjust wondering if yall have any advice. Thanks
Potential2nr
Jan 17, 2012 03:47 PM
sde780
22
Mar 22, 2010 11:49 PM
renzema
Aug 29, 2005 09:42 AM
Kavehman
Oct 7, 2004 07:55 AM
MoogenTypeS
Oct 24, 2003 11:05 AM
