Something strange car vibrate
Old Oct 30, 2009 | 09:05 AM
thunderboy's Avatar
Default Something strange car vibrate
my car begin like vibrating in the left front wheel when i begin run faster i had change the outside cv joint but it still do the same.can someone help me.what can be my problem???
Old Oct 30, 2009 | 11:26 AM
mash Da gas's Avatar
Default Re: Something strange car vibrate
What's the make and model?
Old Oct 30, 2009 | 11:46 AM
thunderboy's Avatar
integra 1995
Old Oct 30, 2009 | 11:51 AM
Simkin314's Avatar
Check your torques on your motor mounts, axle spindle nut, lug nuts, intermediate shaft mounting bolts, etc.
Check over all your suspension components for loose/un-torqued bolts/nuts.
Check your wheel alignment
Old Oct 30, 2009 | 01:13 PM
thunderboy's Avatar
can it be something in the gearbox??
Old Oct 30, 2009 | 02:03 PM
Simkin314's Avatar
I'm sure its possible but not the most likely. I would bet on it being something simple instead, like the wheel came unbalanced (such as if one of your wheel balancing weights fell off).
Get your tires balanced (if your tire is slightly unbalanced, you will feel vibrations especially at higher speeds).
Xvisor
Honda Ruckus and Scooters
Jun 27, 2018 08:23 AM
98civicboy69
18
Jan 16, 2011 05:23 PM
don totoro
18
Apr 24, 2010 03:39 AM
cmyrex
Nov 14, 2006 08:28 AM
Chicano
11
Jan 19, 2005 08:14 PM
