help vtec no working
Old Oct 30, 2009 | 05:24 AM
vtieg6's Avatar
Default help vtec no working
can someone help my b16 engine, my vtec no working.. i have check all my wiring and switch all working fine. wat should i do??
Old Oct 30, 2009 | 07:20 AM
EKcivicEK's Avatar
Default Re: help vtec no working
did you just get the car? maybe you dont have the right ecu. needs to be a p2t or p30.... could be a few others but those are the only b16 ecu's that i know of. if you have something like a p05 v tec for sure wont work cause its not a v tec ecu. plus v tec only works when the car warms up so maybe some type of temp sensor that might not be working???? just some helpful info
Old Oct 30, 2009 | 07:48 AM
haas480's Avatar
what chassis, ecu, etc? speedo working? enough oil? wiring? i believe theres a thread/sticky on here that has all the common issues associated with vtec. an easy way tho to see if the solenoid is even good, would be to hook up a power switch to solenoid. use the single gray clip/plug. when car is off.just touch a wire from the positive terminal to the clip on the solenoid side. it should engage when you touch the wire each time. it'll make a clicking sound. then work from there. like i said, look for the thread/sticky.
Old Oct 30, 2009 | 10:25 AM
vtieg6's Avatar
my ecu is p30 and all sensor and switch working fine. i have try hook up a power switch to vtec solenoid and is working
Old Oct 30, 2009 | 12:21 PM
aemciv's Avatar
did you check oil like haas said. if it is good then you might have an oil pressure issue if its not sensors or ecu.
Old Oct 31, 2009 | 03:13 AM
1992hondacivicvx's Avatar
check ur speed sensor or maybe its dirty take solenoid out it has a little screen on there if its dirty clean it hope that helps
Old Oct 31, 2009 | 06:06 AM
vtieg6's Avatar
i have my oil change so oil is not the problem. i will try out the speed sensor hope it work
thk bro
Old Oct 31, 2009 | 08:49 AM
Unseen Racer's Avatar
did you check your Vtec fluid? it may be low
its right next to your blinker fluid
Old Nov 1, 2009 | 08:04 AM
vtieg6's Avatar
where to check my vtec fluid and how to check whether it at the full level
Old Nov 2, 2009 | 03:46 AM
vtieg6's Avatar
can someone help mi pls ??
Old Nov 2, 2009 | 04:20 AM
Danthemagicbum's Avatar
@OP: There is no such thing as VTEC fluid nor blinker fluid.
Old Nov 2, 2009 | 06:07 AM
well some people consider motor oil as "vtec fluid"
since vtec will NOT work if the oil pressure if low.
Old Nov 2, 2009 | 06:52 AM
vtieg6's Avatar
wt is blinker fluid??
Old Nov 2, 2009 | 02:33 PM
This I did know, I just didn't want OP to ask us where his "VTEC resevior" is.
Old Nov 2, 2009 | 02:34 PM
Old Nov 2, 2009 | 08:09 PM
lol. i know. i just felt like laughing.
do you have any CELs on?
check your oil and your wiring
Old Nov 2, 2009 | 08:13 PM
DOHCtorEK's Avatar
check your oil pressure and make sure you have the right ecu
Old Nov 3, 2009 | 06:33 AM
vtieg6's Avatar
i using P30 ECU and my oil pressure reading is around 2-5 ohm.
i have 1 CEL and it is 20 (ELD) any connection to do with vtec
Old Nov 3, 2009 | 07:27 AM
mortificationrock's Avatar
Thats your problem.
Old Nov 3, 2009 | 07:45 AM
Originally Posted by mortificationrock
Thats your problem.
yup. Vtec will not engage if you have any codes or CELs
Old Nov 3, 2009 | 12:06 PM
pliskin679's Avatar
lol, im bumping this due to the lame title, vtec no working... no working eh? hahaha vtec no working.
Old Nov 3, 2009 | 12:08 PM
pliskin679's Avatar
i actually read the post and i dont think ive ever conidered motor oil to be vtec fluid, im going to say that next time i go to a meet/ show /yell anyone got 5w-30 vtec fluid? im running low!!! maybe a wire got sipped or your ECU is shot?
Old Nov 3, 2009 | 12:17 PM
Archidictus's Avatar
Unceasing Measure
Yeah, let's not do that, okay? We don't need any more traffic/clutter in the forums because some high school kid thought it was funny to bump something with incorrect grammar in the title.
Old Nov 6, 2009 | 05:17 AM
vtieg6's Avatar
so bro wat should i do if my car do not have ELD system??
help pls
thk
vtieg6
Nov 7, 2009 08:16 PM
tgjg19
Aug 17, 2009 07:41 PM
beefjerky
Oct 22, 2007 10:34 AM
HUYNH
Aug 5, 2006 03:43 PM
Mr. Thunderlips
20
Jun 8, 2003 01:21 AM
