B16A2 head on B20 block??
Old Aug 30, 2002 | 11:47 AM
civic disobedience's Avatar
Default B16A2 head on B20 block??
can anyone tell what modifications need to be made to put my B16A 2nd gen head onto a b20 bottom end??
Old Aug 30, 2002 | 12:28 PM
JV's Avatar
JV
Who?
Default Re: B16A2 head on B20 block?? (civic disobedience)
www.b20vtec.com
[Modified by JV, 4:29 PM 8/30/2002]
Old Aug 30, 2002 | 01:34 PM
BROOD's Avatar
Default Re: B16A2 head on B20 block?? (JV)
<holding back >
Basically it involves machining to relocate the cylinder head dowels, plugging the Vtec feed port in the cylinder head deck, running an external Vtec oil feed line, using an ECU that can control the Vtec mechanisms, and a few other points that can easily be found using the search button
(upper right corner of this page )
I really suggest researching this project quite a bit before asking general questions like above. Specific questions are usually answered but the general ones will bring you the "hellfire". Just a suggestion. Plus it is my opinion as well as many others that if you are opting to go for an LSVT engine, you should to do it right if at all. The right build has been discussed many times and is easily found in H-T.
"H-T a great resouce and balanced part of you daily Honda needs."
[Modified by SLPR, 2:37 PM 8/30/2002]
Old Aug 30, 2002 | 07:48 PM
sorry bout the broad question, I actually did try searching the site a few times but didn't come up with anything, a local friend of mine says he knows what needs to happen also, basically I have a B16A 2nd gen turbo in my ride now, I want to start building a bullet proof short block for my setup so I can raise the boost to some out of control level, so basically knowing that it can be done is enough info that I can buy some parts... I'm coming from an old school rear drive V8 world, but have seen the light, and plan to build the baddest civic on the east coast!!!!! great site... plan on chatting much here!!!
Old Aug 31, 2002 | 06:38 AM
BROOD's Avatar
Cool, keep us updated
Old Aug 31, 2002 | 06:13 PM
hybridmoose's Avatar
Default Re: B16A2 head on B20 block?? (SLPR)
I completely agree with these guys! Research , research research! I researched it for about 6 months before I finally built my b20vtec.
Good luck
Old Aug 31, 2002 | 11:56 PM
tinkerbell's Avatar
you musta forgot to check the archives?
check again... there is HEAPS!
t..
Jap_Spec_Imports
Sep 24, 2008 09:01 PM
uses0ap
Jun 2, 2008 03:44 AM
civicb16eg
Jun 24, 2007 08:57 PM
eg6madness
Aug 1, 2002 08:50 PM
lliew
Jan 23, 2002 12:09 PM
