Ignition Switch problem
Old Oct 28, 2009 | 02:20 PM
Stiff_Crx's Avatar
Icon6 Ignition Switch problem
im having a problem with my ignition switch. as i go to turn the vehicle on it shuts right off i just replace the ignition coil where the key goes and i know for a fact its my ignition switch i was woundering if its hard to replace this part and how can i do it.. is there a write up i can read on my 88 crx and if so i hope it has pictures lol please and thanks its driving me nuts im going to try and get another one but it seem complicated. please lmk thanks
Old Oct 28, 2009 | 02:42 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Ignition Switch problem
Well due to this information being theft critical, all I am going to tell you that it is very easy. Get one from a junk yard and replace the whole thing with the harness as one.
Old Oct 28, 2009 | 03:55 PM
D16SiHatch's Avatar
1. Remove the lower steering column cover.
2. Disconnect the ignition switch connector.
3. Insert key and place in the ``LOCK'' or ``O'' position.
4. Remove two switch set screws, then the switch.
5. Reverse procedure to install.
Barf Hat
Oct 9, 2019 05:45 AM
Nicefeet
Nov 9, 2010 05:59 PM
migizzel
Dec 5, 2005 03:46 PM
junlude19
Jan 31, 2005 10:30 AM
