How to determine which O2 sensor is bad
Old Oct 25, 2009 | 02:52 PM
atuvy's Avatar
New User
Default How to determine which O2 sensor is bad
The check engine light is on, I checked with a scanner and the code is listed below, it does not tell me which one of the two sensors is bad. How can I determine that, I would appreciate any help
Code: P1166 HO2S11 Heater Circuit Fault.
Engine Info:
2000 Honda Accord EX 4 Cyl
F23A4
Edit/Delete Message
Old Oct 25, 2009 | 03:13 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: How to determine which O2 sensor is bad
P1166 is the air/fuel ratio sensor, which is the primary sensor.
Here is also a link with a pdf for a few test for code P1166.
http://www.driveaccord.net/forums/sh...d.php?p=229281
Old Oct 25, 2009 | 03:52 PM
92civlude's Avatar
I concur. It is the primary O2 sensor. The clue is in the code, HO2S1. If it were a problem in the secondary sensor, you would have read HO2S2.
Old Oct 25, 2009 | 03:59 PM
atuvy's Avatar
New User
Thank you guys for the quick response. My OBD reader says that it has a problem with the heater but when I turn the ignition on the sensor heats up very quick
Old Oct 25, 2009 | 04:06 PM
P_Adams's Avatar
It may heat, but it is not remaining heated. More than likely the internal resistance is out of range, thus the warning lamp.
P
Old Jul 20, 2012 | 06:45 AM
PMT's Avatar
PMT
Can someone tell me where the air/fuel ratio sensor is on the 2008 civic si and why my dealer wants $583.00 to replace it?
Old Jul 21, 2012 | 12:51 AM
361 accord's Avatar
idk and cuz they suck
here you go http://www.8thcivic.com/forums/do-yo...placement.html
thats everything you need, literally part numbers a place to buy, also try BKhondaparts.com, and autopartswarehouse or even googling the denso part number
all you need is one normal looking wrench, don't bother with those retarded O2 sockets, theres no room to use them on there anyways
Old Jul 21, 2012 | 03:50 AM
tim73's Avatar
I just cut the wires, and use a regular socket(Youre going to replace it anyway). Install use a regular wrench, or a flare socket/wrench
stereodanny
Feb 20, 2019 09:51 AM
bigfoot89
Engine Management and Tuning
Dec 21, 2011 05:22 AM
Steve LeB
Apr 21, 2006 03:58 PM
Rockford2000
Jan 21, 2006 05:51 PM
BAZ
Apr 28, 2004 08:55 AM
