Civic EX sway bar upgrade...
Old Oct 20, 2009 | 08:29 PM
FlewByU352's Avatar
Default Civic EX sway bar upgrade...
Do I just spend the cash and go aftermarket or should I just upgrade to the Civic Si sway bars? Will they make a difference or not worth the cash?
Old Oct 20, 2009 | 08:53 PM
FlewByU352's Avatar
Default Re: Civic EX sway bar upgrade...
after reading this I think it would be smart that I just upgrade to the Civic Si rear swaybar and do the rear disk conversion while i'm at it to get it more neutral because adding the Si front swaybar puts me back to the same understeer
http://www.jdmuniverse.com/forums/view_ekswaybars.html
Old Oct 20, 2009 | 09:01 PM
fastrxu's Avatar
If you upgrade hoth front and rear you'll be neutral and stiff
But then again, go in small increments you dont just wanna get the biggest
Plus you can run the si 13mm rear without a subframe brace which will run $200 by itself ..... So my final advice is 13mm rear
Old Oct 20, 2009 | 09:05 PM
FlewByU352's Avatar
I was just looking at how I would need the SI strut fork or w/e also because of the bigger lower arm and that makes it more complicated. Maybe in the future i'll go aftermarket in the front and rear
Old Oct 20, 2009 | 09:13 PM
roycivic92's Avatar
if u get a big sway bar in the front it will give u understeer
Old Oct 20, 2009 | 09:48 PM
fastrxu's Avatar
Thats what i dis i got the type r 26mm front from eibach.
Eibach makes it for the ex trim as an upgrade so you only nees ex flca's
Old Oct 20, 2009 | 09:49 PM
roycivic92's Avatar
yup i put a gsr on mine its ok
Old Oct 20, 2009 | 10:56 PM
thumper64's Avatar
Front sway induces understeer, but a traction bar will basicly give the same antisway characteristics, no understeer, you can get better launches, it's easier to install since you can keep your non-EX/Si LCAs. It may be more expensive, but you could build one for not too much.
MattBernazzoli
Nov 27, 2009 11:45 AM
stuie08
Nov 25, 2006 02:30 PM
fucT
Sep 5, 2003 06:47 AM
99civic_exSB
26
Jul 9, 2003 09:32 PM
Pravo2
Jan 23, 2002 03:20 PM
