View Poll Results: Change Oil when engine Is warm or cold?
Its better to change oil if engine is cold!
13.89%
It's better to change oil if engine is Warm!
31
86.11%
Voters: 36. You may not vote on this poll
VOTE-Change oil when warm or cold? quick Poll question
Old Oct 20, 2009 | 05:33 PM
EG-SIXV-TEC's Avatar
Post VOTE-Change oil when warm or cold? quick Poll question
I came across that its better to change oil if its cold?
usually i change it if its hot/warm, bc the instructions on the manual said so.
The instructions in the manual said that its better if its warmed up. and wait after 1/2 hour.
Some people says that if its cold that all the fluid is already at the oil pan and you get more of the oil out early in the morning.
Also i heard that its better, because the warmer the easier to flow, but not as much as if it is cold is it true?
Which way change oil if engine is HOT OR COLD???????
also why???
Old Oct 20, 2009 | 05:39 PM
macson's Avatar
Default Re: Change oil when warm or cold? quick Poll question
A lot of people will opt for when it's a bit warm because it's thinner and will drain faster.
I've done it both ways, I don't really adhere to a rule when I do it. Most of the time it's after it's been cooling down for a half hour to an hour, just so I'm not burning myself on **** underneath.
Old Oct 20, 2009 | 05:41 PM
93egSLEEPER's Avatar
i do it warm, drains fatser and more thoroughly IMO.
Old Oct 20, 2009 | 05:47 PM
whats the deal if it is cold? do u get more out or its just better if its hot?
Old Oct 20, 2009 | 05:49 PM
98civdx's Avatar
Master Detailer
Default Re: VOTE-Change oil when warm or cold? quick Poll question
I do it when it warm also.
when oil is cold it tends to be pretty thick, warm its thin, thin will drain better, i have also been told you will get more of the crap out if you do it when its warm.
gwl's Avatar
gwl
Either way, when I leave it overnight there is very little oil in the filter=less cleanup. With a warm engine I will wait 30 minutes.
Old Oct 20, 2009 | 06:49 PM
roadsqueegy95's Avatar
if the cars alrdy in the garage ill do it when the engines cold, but if i have to move the car ill let it warm up first
Old Oct 20, 2009 | 07:24 PM
acake em1's Avatar
Colonel Cake Mix
i do it cold, plus i have the magnetic drain plug too pull out all the metal scraps.. nice little 10 dollar investment
Old Oct 20, 2009 | 07:33 PM
Former User's Avatar
I drive my Civics around the block and then drain the oil (see service manual instructions), but then again I also now have an exhaust pipe blister on my arm.
Old Oct 20, 2009 | 08:22 PM
ferio252's Avatar
^ Thank you. You can't argue with the manual.
An aside, but I always didn't like the dipstick on B16's. Taking it out is simple but putting it back in is like threading a needle in the dark.
Old Oct 20, 2009 | 09:08 PM
dj theoretic's Avatar
wellllll,,,, not cold or too cold, but mild I guess... remember hot you might get a burned if u have an accident LOL!!!!
Old Oct 20, 2009 | 09:54 PM
boxeocampeon's Avatar
yeah dont do it hot cus youll burn yourself do it warm
Old Oct 20, 2009 | 10:01 PM
fastrxu's Avatar
I dont it warm enough as to not burn my self i don have a theory besides the fact i dont like 1-2nd degree burns.
RONJ@HT cool dude i got one too!!!
Its cool its on my forehand above my wrist. I got it a special club. O shet i wasnt supposed to talk about it
Old Oct 20, 2009 | 10:50 PM
thumper64's Avatar
lol, the first rule is I'm not supposed to talk about it. And the second rule is, I'm not supposed to talk about it.
I change my oil when the engine is hot. I just crack the plug loose with a wrench and then use a long extension to spin it out the rest of the way. I wait like 5-10 minutes to let it drain, thread the plug in and drop the filter. Mechanics gloves or a oil filter socket works nice so you don't have to grab the hot filter with bare hands.
Old Oct 20, 2009 | 11:17 PM
98civdx's Avatar
Master Detailer
i normally where a hoodie or something, that way i wont really burn my arms or anythig to bad, the filters suck when then are hot, this last time i ended up getting oil in my eye,
talk about a bitch lol
Old Oct 20, 2009 | 11:22 PM
eg6_trust's Avatar
well i do it when its warn and after that i drope some of the new oil while the drain plug is off until i see the new oil dripping .......
Old Oct 21, 2009 | 02:08 AM
Kista20's Avatar
the drain plug comes out a lot easier when it's hot or at least warmed up.
Old Oct 21, 2009 | 08:58 AM
italian_virus's Avatar
+1
Old Oct 21, 2009 | 09:24 AM
WeakSauce92's Avatar
QUOTE=eg6_trust;40367982]well i do it when its warn and after that i drope some of the new oil while the drain plug is off until i see the new oil dripping .......[/QUOTE]
Old Oct 21, 2009 | 06:58 PM
TheJGB3's Avatar
I usually drain my oil after driving home from work. I let it drain OVERNIGHT, then change the filter, and refill in the morning.
Old Oct 21, 2009 | 07:01 PM
acake em1's Avatar
Colonel Cake Mix
im gonna change mine when its warm from now on
motegicivic
Oct 13, 2011 05:59 PM
TeGGY_LS
Feb 17, 2007 11:33 AM
5lugcivic
13
Aug 20, 2006 05:53 PM
GQ 05YellowEVO8
Jun 4, 2003 07:50 AM
pr0digy1
Feb 5, 2002 10:19 PM
