oil level question
Old Feb 5, 2002 | 10:28 AM
pr0digy1's Avatar
New User
Default oil level question
do u guys know why my lude always seems to show like there's no oil in the engine? About 3 weeks after i bought the car (brand new) i checked the oil and the dipstick was almost dry. i put in a liter and it got a little better. honda said they topped off everything right before i picked up the car. I've gone through my first oil change and the dipstick is dry again. Do any of you have this problem? any ideas why? do i not have enough oil in my car?
btw for my 2nd oil change i'm thinking of putting in synthetic. is that a good idea? what oil should i put in?
thanx
Old Feb 5, 2002 | 11:25 AM
madchiller's Avatar
Premium Member
25 Year Member
Default Re: oil level question (pr0digy1)
are you checking the oil when the engine is warm or cold?
Old Feb 5, 2002 | 12:04 PM
pr0digy1's Avatar
New User
Default Re: oil level question ( DoEs AnYoNe KnOw WheRe I CaN GeT SoMe StRObE LiTEZ AnD LiGhT
i've checked it when it was warm...
Old Feb 5, 2002 | 12:11 PM
The Kernel's Avatar
Try checking it after letting it sit overnight. It takes a long time for all the oil to collect at the pan.
Oh and on a level surface. This should be obvious but ya never know.
Old Feb 5, 2002 | 10:19 PM
typeSwarrior's Avatar
I don't think it should make a difference if it's warm or cold. I have checked mine after driving and when it's cold and its always around the full mark when I'm due for a change. Sounds like either you're not putting in enough oil, you're leaking oil, or your engine is burning the **** out of it, but I seriously doubt the last option, and you'd know if you were leaking it, you can smell and see it. I don't know about anyone else, but 5-6 quarts usually fills mine. If you're cars engine is fairly new and you want to go to synthetic, I don't see a problem with that as long as you use synthetic blend first. I personally use Castrol Syntec oil, works fine.
h22lude317
Jan 9, 2009 08:39 PM
elmoTypeR
Feb 21, 2005 04:08 PM
DVS Luder
Oct 24, 2004 01:55 PM
KCLude01
Oct 13, 2003 01:27 PM
jdwebmaster
Oct 7, 2003 06:08 PM
