EK h22a, not spark, no fuel
Old Oct 20, 2009 | 11:40 AM
hammergunner's Avatar
Default EK h22a, not spark, no fuel
just like it says, i did the ek/h22a swap and converted the alternator and distributor using poisons guide and added in the egr into the ecu jumper.
im using the p13 obd1 ecu and the and the obd1 I believe to be the INTERNAL coil distributor
im not sure, the internal coil is the one without the 5th spark plug wire coming from it right?
is there a special way to convert the distributor and i have a fuel pressure gauge on the fuel rail and i see nothing, so i think something is wrong with the fuel pump.
Old Oct 20, 2009 | 12:25 PM
Former User's Avatar
Default Re: EK h22a, not spark, no fuel
Did you connect the ground wire on the thermostat housing?
Is the ECU fuse under the hood blown?
Old Oct 20, 2009 | 08:59 PM
ok got spark and gas, but motor trys to start but just wont.
i checked the error codes and all im getting is 1st o2 sensor heater.
and well duh i dont have it connected cuz i dont have one.
but i know thats not causing the motor not to start.
i have rc 440 injectors on it, thats the way the motor came.
and they dont have a resister box on them. and i check and they have obd0 injector plugs.
so are they obd0, do they need a resister box at all. or are the 440's just to much gas for no fuel management system?
Old Oct 20, 2009 | 09:09 PM
Is spark bright white or weak orange or blue?
Have you checked the mechanical timing?
Is the engine flooded? Have you checked cylinder compressions?
Old Oct 21, 2009 | 11:57 AM
everthing was already built and timed by someone else.
i just want to know can it be the injectors,
Old Oct 21, 2009 | 12:39 PM
bigblockh22's Avatar
I had the same problem for my h22 ek I had spark and fuel, but my timming was off, make sure you cheak that over.
Old Oct 21, 2009 | 01:00 PM
civic_r87111's Avatar
U have to check the resistance of the injectors with a multimeter to know if u need a resistor box and 440cc on a stock P13 sounds like a flood waiting to happen anyway. I mean stock injectors r either 310cc or 290cc.
Old Oct 21, 2009 | 09:40 PM
i didnt build the motor, but im slapping on some stock injectors, and seeing what happens there. also the car has a walbearrel fuel pump, would take make the injector pump more gas? or just keep the fuel pressure from dropping?
Old Oct 22, 2009 | 09:27 AM
It would just be capable of pumping more fuel and keep the pressure steady, that's all. As long as ur on stock fuel pressure and stock ecu it should work fine.
Old Oct 22, 2009 | 11:47 PM
just looked at the adjustable cams and they are both off zero badly
and the bolts are finger tight!
just sat on the phone for a half hour asking the guy who built the motor about his questionable work.
Old Oct 23, 2009 | 03:54 AM
turbo_d's Avatar
dude that sucks. Hope it didnt mess up your valves... are they both all the way to right?
georgen316
May 18, 2014 12:57 PM
jdmboy94
Apr 25, 2009 07:42 PM
Max_GI
Feb 7, 2008 04:50 PM
lsturboguy
Jun 8, 2007 03:59 AM
HotWheelz
Aug 7, 2003 11:49 AM
