new swap problem!! :|
Old Aug 29, 2002 | 04:12 PM
Malachi's Avatar
Default new swap problem!! :|
alright, i ran the motor for a few seconds with a gas rag and i guess the lines were just try or the pump was, but after about a minute it started getting gas and its fine now. now the problem is when i go to put it in gear it acts like the clutch is always engaged. if i press the clutch i can feel it's fine, like normal. maybe the disk on backwards? what could this be?
Old Aug 29, 2002 | 05:55 PM
HXMan's Avatar
Default Re: new swap problem!! :| (Malachi)
Check that you put the slave cylinder on right...
Old Aug 29, 2002 | 06:39 PM
Malachi's Avatar
Default Re: new swap problem!! :| (HXMan)
yeah, the pedal feels like everything is working right. but then it just stays in neutral.
Alope
Feb 25, 2014 07:29 PM
01typer1124
Transmission & Drivetrain
Jan 11, 2010 09:54 PM
dragonkx
Nov 3, 2009 04:01 PM
KhornLuda
Aug 7, 2006 05:19 PM
