NEED HELP WITH KILL SWITCH ASAP
Why would you ground the switch? How did you wire up your switch?
All i do is take the power wire to the fuel pump, cut it, then put one end of the wire on one terminal on the switch, and the other end of the wire to the other terminal. So in order to complete the circuit for the power to the fuel pump, you have to flip the switch. Is this what you did?
Also be careful if you're doing a fuel kill switch, you could fry your whole fuel harness or your fuel pump
LMAO, you do not ground the wire....
you simply put a switch in the wire so it does not connect when in one position, and is connected in the other
its EXACTLY LIKE THIS, except the battery is one end of the split fuel pump wire, and the car is the other end of the fuel pump wire
the middle pin goes NO WHERE
it willbe like this ... : wire ----> switch <---- wire
Ldo
10
Feb 24, 2009 05:15 PM
StreetRacnGsR
23
Jun 18, 2003 05:05 AM
