Clutch pedal firmness?
Old Aug 29, 2002 | 11:42 AM
Tommy_Gunns's Avatar
Default Clutch pedal firmness?
What causes one clutch pedal to be firmer then another?
Two exact same clutches in the exact same car, however one has a noticably firmer clutch pedal then the other. Is it fluid level, wear, or pedal adjustment?
One thing that I noticed was that the other ITR that had the softer clutch pedal...the clutch did most of the engaging at the last 1/3 of clutch pedal travel (when releasing the clutch pedal), the car almost didn't move at all during the first 2/3 of releasing the clutch pedal. Is this normal cause my ITR starts to move at 1/4 (probably even less than that) of clutch pedal release?
Old Aug 29, 2002 | 11:52 AM
Big Phat R's Avatar
Default Re: Clutch pedal firmness? (Tommy_Gunns)
Pressure plates usually make the difference.
One car could have an older spring (therefore easier to engage) on the clutch pedal itself.
Old Aug 29, 2002 | 11:54 AM
Default Re: Clutch pedal firmness? (Big Phat R)
I have the older car and mine is the one that is firmer.
EDIT: Check out my grammer Ms. Edmonds (my high school english teacher).
[Modified by Tommy_Gunns, 2:55 PM 8/29/2002]
Old Aug 29, 2002 | 11:59 AM
Big Phat R's Avatar
then i'm stumped for suggestions. is this a pressing matter? (no pun intended)
Big Phat R's Avatar
p.s. grammAr
IN VTEC's Avatar
I noticed that on my friend's GS-R too. His catches lower and requires more effort.
While mine catches higher and feels like I'm pushing air.
Old Aug 29, 2002 | 12:01 PM
StageOne's Avatar
I replaced my clutch fluid and the pedal firmed up. Maybe the other cars fluid is old/toast?
Edit for spelling....
[Modified by StageOne, 4:02 PM 8/29/2002]
Big Phat R's Avatar
This is due to clutch wear
BPR - who just changed his clutch b/c the engagement point was getting too high
Old Aug 29, 2002 | 12:10 PM
Willard's Avatar
with same pressure plate being used... the stiffness could come from a build up of clutch dust (or lack of l00b) on the imput shaft collar (where the release bearing slides).
Will
Old Aug 29, 2002 | 12:20 PM
Fugazi's Avatar
New User
Default Re: Clutch pedal firmness? (Willard)
ever since day one mine has been very soft and caught at the last 1/3 of clutch release.
Old Aug 29, 2002 | 12:28 PM
uNF$@#!'s Avatar
Default Re: Clutch pedal firmness? (Fugazi)
most likely air bubbles. bleed the clutch and you will see a noticeable difference.
Old Aug 29, 2002 | 12:35 PM
Default Re: Clutch pedal firmness? (Soup ****)
Air bubbles would make the clutch pedal softer. Mine is firmer and the other ITR is practically brand new (2001 with 14K miles).
AzntaggeR
Aug 8, 2019 09:57 AM
Kermit EK
Jan 29, 2003 03:02 PM
HugoR
Aug 22, 2001 03:54 AM
