itr cams on b20vtec turbo
Old Oct 14, 2009 | 10:47 AM
b20vtecturboeg9's Avatar
New User
Icon3 itr cams on b20vtec turbo
i have a stock b20 motor b16 head blox manifold n block guard t3/t4 turbo on 9psi. my friend is selling some itr cams n gears for $200 will it make a power difference n is it worth it..
i hear it wont n i hear it will aaawhhgrrrr
Old Oct 14, 2009 | 11:04 AM
cm8719500's Avatar
Icon3 Re: itr cams on b20vtec turbo
ITR cams have more aggresive lobes than the B16 cams there for you should gain some power, but i would recomend that you get some dual springs for example ITRs, Blox, Skunk 2 ect. and also tune your car if youre gonna do this the results will be much greater.............
Old Oct 14, 2009 | 12:41 PM
thumper64's Avatar
Default Re: itr cams on b20vtec turbo
This was just answered in another thread. Look up the specs on the cams. ITRs are more aggressive, and almost like Stage 1 cams.
Old Oct 14, 2009 | 01:15 PM
K20egcw's Avatar
ITR's are good, you dont need to upgrade valvetrain unless your goin about 8500rpm's.
Old Oct 14, 2009 | 01:37 PM
komat's Avatar
i would upgrade to itr valve train with itr cams since b16 are single spring on both side
or even get supertech valve spring with rsx type s retainers($45 brand new) if you want to upgrade your valve train
Old Oct 22, 2009 | 03:23 AM
mario_pic's Avatar
whats the acura part # on the retainers
Slow_import
10
Nov 16, 2006 04:00 PM
Charlie Moua
Mar 17, 2003 06:54 AM
InfamousRS
Jun 16, 2002 09:18 PM
cr00klyn718
Mar 17, 2002 02:39 PM
GoQkRaCeR
Feb 17, 2002 12:23 AM
