Bad ELD?
Old Oct 13, 2009 | 09:07 PM
yellowxhoodie's Avatar
Default Bad ELD?
Car: 97 Civic DX
Problem: CEL Throws code, saying i have a bad ELD
Symptoms: Idle Surge? i dont have any of the usual dimming problems.
I have double checked all the vacuum lines, as well as replaced the IACV.
when the motor is running, with the intake off, if i plug the IACV "port" on the inside of the TB the idle surge stops. (this is what led me to believe it was the IACV to begin with)
my buddy thinks its the ELD causing the surge, is he right?
i have been searching for weeks and double checking everything and still no luck.
i have also seen the TSB on this issue, my engine harness is brand new so i know this is not the problem...
suggestions? ideas?
PLEASE HELP.
i need this car running asap for winter.
Thanks!
Old Oct 14, 2009 | 04:27 AM
Default Re: Bad ELD?
bump
Old Oct 14, 2009 | 05:08 AM
RagnarX's Avatar
I had the same cel on my 95 hatch, cleaned the terminals and the grounds and it fixed it. Not sure if that will fix your problem tho. I didnt have idle surge.
Old Oct 14, 2009 | 06:43 AM
on all the ground terminals in the bay?
ill give it a shot.
i put a new motor in the car. (still a D16, but the block was from a 92-95)
it didnt have the ELD CEL before the swap, so idk why it would show up now...
Old Oct 14, 2009 | 03:43 PM
bump for any other ideas?
im going to check the battery ground tonight as well as the 15 fuse.
Old Oct 14, 2009 | 03:49 PM
Former User's Avatar
Check whether 7.5A fuse #15 under the dash is blown.
Old Oct 14, 2009 | 04:32 PM
yea, i planned on it tonight, i will post after i do that.
Old Oct 14, 2009 | 05:16 PM
Fuse 15 seems fine. Im going to try to stop by a buddies house later tonight to grab another one from him just to double check.
Old Oct 14, 2009 | 08:10 PM
changed fuse 15 with another 7.5...that didnt work
then changes it with a 10...that didnt work either
any more suggestions?
Old Oct 14, 2009 | 08:13 PM
Is your 97 Civic completely stock? Any mods?
Old Oct 14, 2009 | 08:32 PM
basically.
i started doing a wire tuck, and its on its 3rd motor.
the block is from a 92-95 civic though. but i dont see why that would have anything to do with this.
Old Oct 14, 2009 | 08:36 PM
Make sure the ELD connector on the underside of the hood fuse box is plugged in. If so, check for a short in the Grn/Red wire running between the ELD connector and pin D16 of ECU connector D.
Old Oct 16, 2009 | 02:59 PM
i didnt have a chance to check anything out yet. BUT,
i was driving the car today doing some errands the idle surge stopped...
scanned it and the code was gone as well.
idk how, idk why, and i dont really care.
im just going to keep my fingers crossed that it doesnt come back.
k2day
Nov 19, 2011 09:38 PM
Todhunter
Nov 23, 2010 12:55 PM
Midnight-Bullet
Jul 12, 2009 02:45 AM
^MikeG
Jul 13, 2005 11:33 AM
dsadas89das78934
Jan 15, 2004 08:01 AM
