Lighting forum was no help on wiring HIDs
My friend did a retrofit and gave me his old PnP hid setup that works fine, so I'm going to use them in my Denji Projectors.. I'm not a n00b and I know these are hated amongst many, but they were free and I'm rocking a nice clean cutoff already with my projectors so I'm assuming these will function just as legitimately.. Also, he failed to keep the instructions and he had them kinda ghetto-rigged in his EK so I'm aiming for a more clean and satisfactory install in my EG..
Ok so I basically just need to know what to do with all the white/black wires..?? There are a set coming from each ballast and there are a set plugged into the OEM plug on the relay harness.. I've heard I could just wire the HID's directly to my headlights but I think just for security and retention of better knowledge, I'll still use the battery/relay harness..
Here is the image I took to assist in helping..
And the original thread from the Lighting forum..https://honda-tech.com/forums/lighting-107/given-hid-kit-what-else-do-i-need-2661287/
