Random Turbo Questions...
Old Aug 29, 2002 | 08:00 AM
01ITR#700's Avatar
Default Random Turbo Questions...
Hey guys my Turbo Type R is alomost done and I have a few questions if anyone can help me out.
1. Tial WG question, at idle should any heat/hot air be coming out of it through the big opening in it?
2. I got a Tial WG and BOV, in the box was a small aluminum ring, I have no idea what it goes to? It's smaller then the flanges on both the WG and BOV.
3. Autometer Air Fuel guage issues, it seems to light up nice and bright initially and "flutter" around for about 10 seconds, then it slowly goes over to the lean side and then goes dim and you can't see it anymore?
4. Is there any physical way to get an alluminum BOV flange onto an Alluminized steel charge pipe?
5. The WG hits the hood just barely, what do you normally do about that? It's hitting the frame/skeleton of the hood so I was thinking maybe just trim a little nothch to make room?
Those are all the questions/issues I'm currently having and appreciate any insight you all may have.
Thanks.
M
Old Aug 29, 2002 | 11:31 AM
B18EG6's Avatar
Default Re: Random Turbo Questions... (01ITR#700)
that ring needs to be placed between the wastegate and the manifold...
the AF gauge will "flutter" a little bit...thats how the ECU averages it out to be a nice AF ratio.
correct me if im wrong, but no air should be coming out at idle...u need to put the ring in there to fix this.
my wastegate hits the hood too, i hate it.
i dont want to be a dick and point out the obvious, but u need to connect the charge pipes
Old Aug 29, 2002 | 11:43 AM
01ITR#700's Avatar
Default Re: Random Turbo Questions... (B18EG6)
Cool, thanks. I have about 12" of pipe I need to run to get the car on the road
The air fuel guage is still screwed though, I have had them before and know what they are supposd to do but it literally flutters for a second then goes to full lean and the light goes away and doesn't come back until I turn the car off and back on again, I assume I tapped the wrong wire or something?. I assumed that's where that damn ring went but didn't have time to pull the WG off and check last night.
Thanks.
M
Old Aug 29, 2002 | 12:20 PM
Etylorcen's Avatar
You dont need that top fitting on your tial unless you plan to run an ebc. Otherwise take it off and you'll clear your hood.
Old Aug 30, 2002 | 12:50 AM
vtectuner99's Avatar
Default Re: Random Turbo Questions... (Etylorcen)
i have the same wastegate on my civic and it hits the hood take it off if you are not using a boost controller
Old Aug 30, 2002 | 01:24 AM
TedR719's Avatar
Default Re: Random Turbo Questions... (vtectuner99)
Looks good Mark
Orangecivic251
Dec 19, 2006 07:58 PM
4_door_teg
Jun 17, 2006 09:46 PM
WangChung
Mar 28, 2004 09:21 PM
spike
Dec 28, 2003 09:14 AM
B18C-RnVA
Nov 9, 2002 07:16 PM
