Internal BOV . . . ??????
Old Mar 25, 2004 | 02:08 PM
WangChung's Avatar
Default Internal BOV . . . ??????
ok, my friends dad has a sandrail with a built v-dub motor in it. it is turbocharged, and he claims to have a "mercedes t3" turbo. he also said it has an internal blowoff valve and wastegate. i understand the wastegate, but how the hell can it have an internal bov? i checked his setup and there is no bov present, but it makes the sound between shifts. can someone explain?
Old Mar 25, 2004 | 07:38 PM
WangChung's Avatar
Default Re: Internal BOV . . . ?????? (WangChung)
bump for a retarded question
Old Mar 25, 2004 | 08:05 PM
VNTEC's Avatar
B A N N E D
Maybe internal meaning the gases the bov releases goes back into the intake of the motor
Old Mar 25, 2004 | 08:24 PM
JonGP4's Avatar
Default Re: Internal BOV . . . ?????? (VNTEC)
yeah, or there is some flapper on the compressor side of the turbo, i saw one on an old diesal turbo.. could be that..
Old Mar 25, 2004 | 08:28 PM
WangChung's Avatar
Default Re: Internal BOV . . . ?????? (JonGP4)
thats it, keep 'em comin people!
Old Mar 25, 2004 | 08:33 PM
J337_UNIT's Avatar
i totally understand the concept behind it, but personally have never seen it
Old Mar 25, 2004 | 09:36 PM
Bailhatch's Avatar
Default Re: Internal BOV . . . ?????? (J337_UNIT)
I had a vlovo turbo with an internal bypass vlave. I took it apart and it was actually built quite well. Basicly it just dumps air from the outlet of the compressor back into the inlet about 3/4" in front of the compressor through a rectangle slot in the side. it wasn't a flapper, it's a nice steel and brass plunger like a greddy type S or 1g DSM.
it works just like any bypass valve just there is no piping between the compressor and the valve.
Old Mar 26, 2004 | 07:08 AM
WaltersCivic17's Avatar
Default Re: Internal BOV . . . ?????? (Bailhatch)
yeah thats my sandrail biznatch pce chris its fastr then ****
Old Mar 26, 2004 | 07:12 AM
DaX's Avatar
DaX
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">I had a vlovo turbo with an internal bypass vlave. I took it apart and it was actually built quite well. Basicly it just dumps air from the outlet of the compressor back into the inlet about 3/4" in front of the compressor through a rectangle slot in the side. it wasn't a flapper, it's a nice steel and brass plunger like a greddy type S or 1g DSM.
it works just like any bypass valve just there is no piping between the compressor and the valve.</TD></TR></TABLE>
Is this similar to a compressor with a ported shroud?
Old Mar 26, 2004 | 09:55 AM
WangChung's Avatar
Default Re: Internal BOV . . . ?????? (WaltersCivic17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WaltersCivic17 &raquo;</TD></TR><TR><TD CLASS="quote">yeah thats my sandrail biznatch pce chris its fastr then ****</TD></TR></TABLE>
oh, so u can post now?
Old Mar 26, 2004 | 10:45 AM
Bailhatch's Avatar
Default Re: Internal BOV . . . ?????? (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">
Is this similar to a compressor with a ported shroud?</TD></TR></TABLE>
kind of in that there are openings in the compressor inlet but thats about it. Ported shrouds have nothing to do with a bypass system unless you just mean the layout of the holes.
The one I had was about a 1/2" x 1 3/4" slot in the side of the compressor inlet. So if you were looking straight into it you coulden't see the hole. The ported shrouds can be seen easily from that angle.
Old Mar 28, 2004 | 05:33 PM
dohcdelsol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WangChung &raquo;</TD></TR><TR><TD CLASS="quote">
oh, so u can post now? </TD></TR></TABLE>
Dont get trigger happy yet, where's ur % points???
And yes, this is a very n00b question. ******* NEWB
23rd biotch
Old Mar 28, 2004 | 09:21 PM
WangChung's Avatar
Default Re: Internal BOV . . . ?????? (dohcdelsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol &raquo;</TD></TR><TR><TD CLASS="quote">
23rd biotch </TD></TR></TABLE>
its from when i called Drew a douchebag. haha!
holsetcivic
Apr 21, 2009 08:49 PM
Orangecivic251
Dec 19, 2006 07:58 PM
b18bturbo
Feb 18, 2004 07:14 AM
DownBoyDown
Feb 2, 2004 09:19 AM
b18tdelsol
Jun 3, 2002 11:15 AM
