jus got a new turbo
how much boost u trying to run? Stock map is good to 11. something psi i believe.T off your brake vacuum boost hose and use that as a vacumm source. External wasgate vacuum to compressor housing.
Again, this depends upon the turbo that you're using. 7psi from a GT28R is different than 7psi from a 57 trim. Either way, the injectors have to be tuned to run with any kind of reliability. A standard Walboro 255lph 342 fuel pump can work, but you MUST BE TUNED FIRST before you can run even 1psi of pressure.
Do yourself a favor. Don't install this yet until you have ALL of the components needed to boost this engine, especially if this is your only mode of transportation.
Check this link out. This should answer A LOT of your questions in full detail.
https://honda-tech.com/forums/forced-induction-16/%2A%2A%2Aforced-induction-forum-faq%2A%2A%2A-1024174/
Thanxs a lot I jus bought a walbro 255 feul pump im debating in wht sice injectors to use
And with the tuning I just move out to memphis 4rm Los angeles and I have no idea where to get my car tuned out here
450cc DSMs require a resistor box with a maximum output of about 250whp or so. Knowing more about the components of your setup. (no PSI numbers please) will help us, help you.
Def need injectors of some type. The black tops are great for basic kits and are usually easy to find. It is also really easy to wire in the resistor box. Also Management is a must. There are a lot of "alternate" management options. I made 300 whp on a bone stock B16 with DSMs and uberdata, but the injectors were MAXED. When I got tuned my FPR was cranked all the way up to keep up with the boost @ 10lbs on a T3/T04e which is not that large of a turbo.
He is in TN USA so i highly doubt he is a foreigner or can't speak ANGLISH!
projectef
15
Jul 9, 2007 04:42 PM
