shaved bay
Was in process of shaving my bay and been lookin an was seeing diff. things use to fill in holes..and was wondering what is best thing to use for heat under the hood and all? any advice is appreciated
thanks
thanks
you can do it 2 diff. ways for certain areas. easiest way is to weld all the hole then grind them smooth then filler over them.
i welded almost all the holes cept. the rad support where i back glued the rad support then filled over it ill post pics of it
