Bondo the engine bay?
Old Sep 21, 2007 | 05:43 PM
rdssk8rcs1's Avatar
Default Bondo the engine bay?
Is bondo good to use inside the negine bay? I plan to fill a lot of the holes with weld and grind them down and use something like bondo to make it smooth.
Whats the best thing to use?
Old Sep 22, 2007 | 04:35 AM
WihaSi's Avatar
Default Re: Bondo the engine bay? (rdssk8rcs1)
I would say that using body filler after welding and grinding is fine, unless you wanted to use some duraglass or something. Body filler is a bit easier to work with though.
Old Sep 22, 2007 | 06:21 AM
SoDakCRX's Avatar
duraglass will probably be your best bet, out of the 2 mentioned here. its fiberglass based which means its waterproof. which you will need after grinding/welding.
some of the other threads i have read on tucking/shaving engine bays mentions "blue icing"?? i think thats what its called
Old Sep 22, 2007 | 07:07 PM
rdssk8rcs1's Avatar
Default Re: (SoDakCRX)
is blue icing the brand or a different product?
Old Sep 24, 2007 | 07:00 AM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
This thread has tons of info on eng bay shaving. The first page has some good reference info, including types of filler for the bay.
https://honda-tech.com/zerothread/1693934
markD.
Paint and Body
Mar 31, 2011 05:16 PM
dev203d
Welding / Fabrication
Nov 18, 2010 02:37 PM
dc4teg95
Paint and Body
10
Nov 23, 2009 12:59 PM
RedneckRicer
Paint and Body
May 10, 2008 06:33 AM
rdssk8rcs1
Paint and Body
13
Nov 17, 2007 08:13 AM
