shaved bay
Old Oct 10, 2009 | 02:55 PM
Spoolbeast's Avatar
Default shaved bay
Was in process of shaving my bay and been lookin an was seeing diff. things use to fill in holes..and was wondering what is best thing to use for heat under the hood and all? any advice is appreciated
thanks
Old Oct 12, 2009 | 08:51 AM
samba_green_sol's Avatar
Default Re: shaved bay
Weld them
Old Oct 12, 2009 | 06:12 PM
vsmhatched's Avatar
weld most of the holes and what you cant fill in, use a skim coat of Evercoat metal glaze.
Old Oct 12, 2009 | 06:43 PM
shocker911's Avatar
you can do it 2 diff. ways for certain areas. easiest way is to weld all the hole then grind them smooth then filler over them.
i welded almost all the holes cept. the rad support where i back glued the rad support then filled over it ill post pics of it
Old Oct 12, 2009 | 06:45 PM
shocker911's Avatar
its dirty havent cleaned out the bay in weeks
Old Oct 15, 2009 | 04:59 AM
2much4u's Avatar
That is how a body shop would do it. But for metal glazed i would stay away and weld everything you want to fill. So it will last.
Old Oct 15, 2009 | 08:56 AM
dc4teg95's Avatar
weld them then grind them down. i would also use evercoat poly-flex glaze putty to smooth out as its a flexible filler and less prone to cracking over time.
Old Oct 16, 2009 | 06:36 AM
thetireman's Avatar
bumppp
Zeronamous
Paint and Body
Oct 12, 2015 11:25 PM
markD.
Paint and Body
Mar 31, 2011 05:16 PM
dev203d
Welding / Fabrication
Nov 18, 2010 02:37 PM
dc4teg95
Paint and Body
10
Nov 23, 2009 12:59 PM
rdssk8rcs1
Paint and Body
Sep 24, 2007 07:00 AM
