Ehaust manifold bolts are breaking
Old Oct 9, 2009 | 09:23 AM
B00$t3d's Avatar
New User
Default Ehaust manifold bolts are breaking
I had used the stock bolts that connect the exhaust manifold to the block, now some of the top four bolts have snapped and some look like they are missing, I have a leak now and I'm going to be in the process to take everything off to fix this problem. First question is: is it ok to drive for a couple of days where it wont do any damage to the engine (the Y band is a little off -i know due to the leak) and what size are those bolts and what would be a good grade to get for those.
Old Oct 9, 2009 | 09:45 AM
coneheadsracing's Avatar
Default Re: Ehaust manifold bolts are breaking
not fixing them, you risk stripping them all out, if you already haven't. I would be more concerned with figuring out why your ripping them out, rather then a good upgrade. I use stock 10+ year old bolts and no issues. You may want to look into, motor mount upgrades, and a flex pipe.
gosu08
Nov 25, 2009 04:53 PM
eskimo10
12
Jan 3, 2008 07:47 PM
leadtrum
Apr 12, 2004 04:54 PM
brian b
Aug 4, 2003 05:11 PM
hybrid901
Nov 7, 2002 08:24 AM
