Senior Project Ideas
Hey my name is Brandon i have a 93 civic coupe and need some senior project ideas while also adding to my car
Mods So Far
-racing coilovers
-new exhaust including headers
-headwork done
-new interior seats and carpet
-new side mirrors
-intercooler setup
Requirements
-15 hrs of field work (min)
-have to have a meteor that is over 18 and experienced
-be able to write a 6-10 page paper on a related subject
hit me back if you have any ideas
Mods So Far
-racing coilovers
-headwork done
-new side mirrors
-intercooler setup
Requirements
Full engine build and explain why you used the bore, stroke, cams, rods, bearings, etc you did. You could port, polish, flow bench the head. Custom build a new chassis from tubing like you'd use for a dune buggy.
Design a header and exhaust system, or better yet a turbo setup, that is matched to your needs.
If you want to get real in depth, you could spend 15 hours just researching header design.
Pick up another motor and totally build it all up from scratch. The motor will be cheaper and it will be more time towards the project and another place to fudge numbers on if you're a couple hours short or whatever.
I've seen and even had a D15B7 I was going to give away, it just needed rings and valve seals. I mean, really. That's like a $70 repair or like $200 to totally rebuild.
benclimber17
Feb 25, 2008 07:47 AM
ExploitedRacing-HR
Welding / Fabrication
Feb 19, 2005 06:04 PM
Inigo Montoya
Mar 27, 2003 06:23 AM
