Why does my power drop off once it hit 7k rpm? Dyno included
Old Oct 7, 2009 | 02:38 PM
StolenTeg's Avatar
Default Why does my power drop off once it hit 7k rpm? Dyno included
My set up is pretty basic,
9.5 Wesico piston
Eagles rod
81mm stock sleeves
B18b1 block with B16a head(100% oem)
ITR cams
oem throttble body
victor x manifold
topmount manifold>3 inch downpipe>open Y pipe
Precision SC6152e
1000cc RC Injector
I dont get why it hit a brick wall at 7k rpm, is it because of my head/throttle body?
I've seen many different setup graph with stock head/TB and they are all smooth?
Old Oct 7, 2009 | 03:21 PM
1DayIllBFast's Avatar
Default Re: Why does my power drop off once it hit 7k rpm? Dyno included
what plugs are you running? what are they gapped at?
Old Oct 7, 2009 | 03:24 PM
StolenTeg's Avatar
http://www.summitracing.com/parts/NGK-4554/ gapped at .016, the car is not breaking up.
Old Oct 7, 2009 | 03:25 PM
JDogg's Avatar
how much boost? could be floating the valves
Old Oct 7, 2009 | 03:28 PM
StolenTeg's Avatar
23lbs, make sense for it to be the valvetrain
Old Oct 7, 2009 | 03:38 PM
Kensai's Avatar
Yeah, you need to upgrade the valvetrain. Stiffer springs and tit. retainers would help a lot. Head makes all the difference after 7k rpm.
Old Oct 7, 2009 | 04:45 PM
IceySC's Avatar
how many psi were you running ?
Old Oct 7, 2009 | 05:07 PM
96 GSR-T's Avatar
What did the tuner say?
Old Oct 8, 2009 | 06:19 AM
JDogg's Avatar
if you keep it up you're going to crack a retainer, so even if thats not THE problem it will be A problem
Old Oct 8, 2009 | 11:35 AM
Garage 808 Hatch's Avatar
Looks like unsteady boost levels, tire spin, cam timing issues etc. there are multiple situations that can cause graphs like that
Old Oct 8, 2009 | 02:39 PM
StolenTeg's Avatar
Definitely not unsteady boost level or tire spin, im going to be putting in some super tech valve spring and see what happen.
Old Oct 8, 2009 | 02:57 PM
JDogg's Avatar
make sure to replace the retainers as well
Old Oct 8, 2009 | 03:14 PM
96 GSR-T's Avatar
x2
Old Oct 8, 2009 | 03:15 PM
StolenTeg's Avatar
Here a graph at 15 psi, the drop off is noticeably less
Old Oct 8, 2009 | 07:18 PM
blackeg's Avatar
did you guys try adding 1-2* timing back in above 7k and see if it helps? what is the total timing up at redline out of curiosity
Old Oct 8, 2009 | 08:11 PM
jdm602's Avatar
if you could, logging the afrs would help some. and yea whats timing up top? also are the cams degreed at all?
the graph is interesting to look at. those peaks at 6k and 7k look odd.
what wg and spring is on the setup?
Old Oct 9, 2009 | 01:56 PM
StolenTeg's Avatar
As far as data logging i dont have that but im pretty sure the a/f ratio were in the 11-11.5 in boost.
this was on stock cam gear, full-race top mount with 44mm tial gate with 14 psi spring. boost plot is solid so it not a fluctuation issue.
Old Oct 9, 2009 | 04:52 PM
spoolin turbo s's Avatar
seems odd it would be the valvetrain since it does it at the lower boost level as well.........
i mean you don't see a stock motor's dyno do that at 7k rpm's
seems odd...
Old Oct 9, 2009 | 05:02 PM
StolenTeg's Avatar
Only other thing that could be a problem is my down pipe, i have a 5 bolt to v band adapter that is 2.25>3 inch but the turbo outlet port is 2.5 but that shouldn't make the graph look like that?
Old Oct 9, 2009 | 07:01 PM
96 GSR-T's Avatar
^^^^ Thats definately a place to start, you should not choke off the outlet of a Turbo.
Old Oct 9, 2009 | 10:19 PM
jdm602's Avatar
does it smoke at all? how good is the turbo? maybe a seal is done for.
Old Oct 10, 2009 | 06:05 AM
boostedEF91's Avatar
yeah. fix your exhaust.. that could be hurting it at that power level. is your intercooler big enough as well.. maybe the airflow isnt flowing well. could be alot of things.
sc34dx
May 13, 2010 11:13 PM
Boosted Chemist
Jun 24, 2009 08:35 AM
92SR4WS
Dec 26, 2008 10:22 PM
VTC_CiViC
Jan 5, 2005 11:09 AM
