Spoon crate motor
was wondering how much these make? i looked around couldn't find anything specific for a b18 some1 said around 200 for a b16? was wondering if any1 could get me some real info on it
Info from inlinefour.com's website says its a factory engine disassembled, balanced and blue printed and then reassembled. Engine is designed for endurance racing. The only thing not factory is the the 2 layer head gasket.
I would guess slightly (2-5 HP)more than factory HP figures due to balancing and head gasket.
you should check out kingmotorsports.com, they are not spoon (official mugen distributor in north america) but offer crate motors that they build in house. Im not sure and to lazy to go look but I think htere b16 puts out 200hp. You must provide your own engine and then they rebuild it i believe.
http://www.kingmotorsports.com/category.aspx?cat=99 (bottom of the page)
maybe the least I should do is install the new valve seals, maybe a DIY is in order for that.
Not much more than stock. Spoon motors where used for FIA Group N racing which forbids modifications or extra power adders. You are better off just building what you want if you want power. If you want a balanced, blueprinted engine that will run a race season with as little potential maintenance as possible then get a spoon.
Very true! I just had to give ya some ****. I loved all the guys hatin' on you for not installing it. They just say that because they wish they had a perfect crate motor sitting in waiting.
I didnt see that but I just want to know if that has been maintained all this time or not. If it hasn't, will the crank still turn by hand?
